My Nissan is slow at accelerating because I don't mash on the gas at every light. I keep the RPMs low.
Is it slow? I will never know because I have never had it over 75 MPH.
I have yet floor the car since the dealership test drive and that was just to see what it had.
Sounds dumb but I barely pay attention to the RPMs and I drive it like it's the old wagon that could explode at any moment. And it's still plenty peppy. 😂
I ran the "big" errands of cardboard and groceries since the train was too late to give me my work for today and it was such an awesomely anticlimactic experience that I was giddy over it. Like this now normal people live lives that they hate and I'm excited to be one of them.
Both mine have that feature with average and real-time MPG. The thing is, I don't pay much attention to it with a 6000 pound truck. If I'm first at a light and it turns green, I'm gone. I want away from all those idiot that got stacked up behind me. So it gets 16mpg. Who cares? If I wanted fuel mileage I would have bought a ricer.
I don't think it makes much difference how you drive a pickup. They're gonna get shitty MPGs anyway.
Still showing 30mpg average since topping off on Thursday.
I bet @Duck would see it in the low 40s running out there with the same pedal discipline. I'm not even hypermiling. I'm setting the cruise at 68 and letting it roll, albeit letting it pace traffic ahead. Certainly helps the fuel economy some.
Late at night when there's no traffic, you can make left turns at like 40 mph if you cut early, shave the inner curb and go wide to the right lane after turning.
Just open Google maps and find a random intersection, one with painted lines you can see, and visualize the widest radius curved path you can follow around a left turn.
I've done it with right turns but rarely. You can't have any witnesses or they'll think you're drunk.
But the faster you can whip a corner without excessive sideload, the more you fuel you save.
Brakes waste kinetic energy that you accumulated by burning fuel.
So the brakes are your fuel economy's worst enemy, even if they're safety's best friend.
Just don't be stupid and crash 😂
This car is going to seem laughably cheap to maintain compared to everything else I've ever owned. Oil capacity is 3.9 quarts WITH FILTER. $28 for Mobil1 Full Syn 5qt jug and $10 for an OEM filter shipped free from Wally World. Ordered it yesterday, arrived today. The filter is a tiny little thing about the same size as the one on my zero turn. That oil and filter combo is good for at least 7500 miles which at my current and past rate is annual if not longer mileage wise.
I didn't get transmission stuff yet because I want to get it from the dealer first time out to see what the OEM spec is, if it's anything special. If it's some kind of weird concoction I'll just keep getting it there to be on the safe side. I do the same for Mack oil and filters. I get the high dollar OEM stuff just to try to make it last longer. Costs me the same for those materials as paying a shop to change it using cheaper bulk stuff. I have an account with the Mack dealer which knocks the price down on some stuff, one of which is oil and filters.
On the Honda there are maintenance minders on the dash for oil and trans service. So I'll probably just go by those. Oil is fresh and still shows 100% left when I go to the life left screen. I can't find the same for the trans. I'm reading that it's kind of an idiot light of sorts because it's based on usage not just miles over time. There's an HRV forum that says the 25k interval is mostly for mountain driving at low RPM because of the heat. I'm not retarded enough to not downshift to get the RPMs up to make the fluid flow and don't climb mountains as a rule so it may never apply to me. I live in a valley and only hop the "mountains" when I need to change valleys.
best to get a gallon or 2 of Hinda coolant as well...
i have Toyota coolant, bought at the dealership and was not high priced.
the NAPA, AutoZone, and others claim to be an exact replacement.
i checked into that and found differences from OEM Toyota to the others.
can't recall right now, but enough to make me go to the dealership.
Toyota synthetic oil IS Mobil 1, just labeled as Toyota.
when i did a quick gig at Jiffy Lube as a manager they did transmission flushes...they had "generic transmission fluid", with a seperate additive for the different car makers specs. that crap had to be measured exactly, as too little, would cause problems...and any extra amount was a waste.
i'd stick with OEM, and unlike you, i'll go to the dealership for transmission fluid changes. since the process is too involved for me, and the lack of some electronics.
Mack cost me an extra trip to the dealer thanks to their schematic being incorrect. Also dumb on my part not paying closer attention to what I already had.
I went down yesterday for the new bolts and bracket. I get the bracket and compare it with what I remembered of the part number stamping and the direction the factory schematic showed it it being installed and I go whoa wait this is all wrong. The holes are on the wrong end (it's mounted to the left side tank strap only). So after some digging around for other possible part numbers (mine and the new one did match), I decided not to buy the bracket and take just the bolts, figuring I'll muddle through drilling out my original.
Turns out the schematic showed the orientation in the opposite direction, and they stamped the part number in it accordingly.
IOW if I installed it backwards as shown, the part number would have been in the same location as my memory recalled the original. Problem is I didn't look at it close enough to see which direction it was facing, otherwise I'd have remembered that. Once that bolt snapped, my only concern was getting a new one ordered.
So I went back down today and fetched the new bracket and put it on. It fits fine, matches the original, just has the part number on the opposite end and facing away.
It's kind of a hidden bracket so having a pretty one now is a bonus but not particularly necessary, even for my OCD. You have to look up under the plate to see it.
Most times when doing a usually easy repair, you have to get 3 things out of the way just to see what you are about to replace. Once they are out of the way, the job is as normal.
Truck ran awesome again today. Don't wanna trade it until I drive past that beautiful Mack sleeper that's old enough for me to maybe be able to afford. Then when it's out of view I don't want to trade it again.
Fuel economy and pulling and ride was excellent today again. Similar to yesterday and Sunday.
I think the shiny new deck plates gained me 50 horsepower. The bracket was probably good for 7. The aerodynamics of less rusty bolts probably gained me a tenth of fuel mileage. Air slips right over them now.
Imagine the gains if I polished my tanks. Boy howdy!
I also went with the dealer coolant because things are much more complicated these days with the metals used and the chemicals in coolant. It was priced about the same as you would get from the auto parts store store.
I also did the first transmission oil change at the dealer because it was still under powertrain warranty and I figured they can't come back at me if something happens when they were the ones that did the work.
