Electric Chicken
Trying to do the math on my living expenses if I laid in bed and did nothing for the rest of my life.
It's 3 lug nuts, bro. I'm not up here in a tire shop doing this every day.that's not a spline drive.......
for tire work, most shop mechanics i had been talking with, at the very least a 1" drive impact, and a real spline drive..
this is a spline drive
in time, you are going to snap that shaft.
i have seen them snap.It's 3 lug nuts, bro. I'm not up here in a tire shop doing this every day.
They sell 3/4" anvils for it, I bought them, and I wanted to see how it would fair against real 3/4".
It did what I expected it to do.
It's got internal splines for the interchangeably. So it is spline drive.
Not sure how that anvil is ever going to snap.
I have never seen one snap. The hammers cam over the anvil when stuff is tighter than the impact can remove, so it just sits there doing nothing.i have seen them snap.
over torquing is one way....removing over torqued is another.
it is not a spline drive on the socket end. at least not in your video.
it is a splined shaft...and even that right now, is internally.
unless it is a 1" drive, that will not last you very long....doing H.D. work.
Anything different? Or are they finally figuring out you have been good the last 1000 times you have been across the plate?Oh and I'm finally getting green lights on my PrePass. Knock on wood that it continues.
Nothing different that I know of. I haven't even shaved.Anything different? Or are they finally figuring out you have been good the last 1000 times you have been across the plate?
one of those "plastic oil pans"...or metal..??Cleaned up the pan to put some RTV around the plug. Turns out the pan itself is cracked. I threw some RTV over the crack just to do something but I'm not pushing my luck any further. The crack goes right alongside the plug so it started small and obviously got bigger, and explains why I thought it was the plug.
I'm running it down ASAP to get that replaced and also have my fuel tank put on finally since it looks like I'm keeping this truck a little longer.
With the fuel mileage I've been getting lately I'll be able to run my usual and get ~3 days out of a fill-up and be more opportunistic about my fuel.
I stuck a magnet to it. It's metal.one of those "plastic oil pans"...or metal..??
one company i worked at, had to replace the plastic ones every so often due to cracking
I'll have to learn that.better off brazing it
