well i think it's not only about the $$$ though that has a part in it. but it's all about the freedom and running how you want and going where you want and not being micro managed buy some idiot dispatcher not saying there all bad along with having to deal with office politics. even freedom has it's price but worth it in the end
none of us like to be micro-managed or followed , and want our freedom.
but none of us want the headaches, after the day ends...for us working stiffs, the day ends, we go home till the next day....all those that are in charge, or own the business have the worries about money, expenses, and whatever else.
like said earlier.....working for yourself is NOT always what it is cracked up to be.
i was always happy being a lowly working stiff......and that hasn't changed.
TBH I'm just frustrated at not making the money I used to. It wasn't too bad even with the lowered rates when I got a "long" run paired with one or two short runs.
But now all I get most days is the one "long" run and it's actually not very long and has the worse PPM to fuel ratio of anything.
The short runs would boost the gross and didn't use nearly as much fuel so they offset the low rate of the longer one.
My tolerance for the containers themselves dropped like a rock when I stopped making reasonable money.
I don't mind working on the truck or the paperwork either, as long as I have the revenue to justify it.
Without the revenue, parking it keeps sounding smarter and smarter.
The alternative being to get a sleeper to run more longer ones, with the expectation to actually be sleeping in it.
To be fair, I actually enjoyed regional with Schneider. I was less edgy and far more affable to do whatever. So with me trying not to be a failure in this, I'm still considering that option.
I'm actually thinking about taking a week or two off, getting a rental car, and running around all over the place to look at these sleepers I see online.
when i was in the repair business, as mechanic/manager, i saw the ups/downs of daily income to expenses.
some days, i had to let my helper go home, but i had to stay, since i was afterall in charge
then things turned around, when those IRS refund checks came in.
you know darned well the cycles in trucking.
maybe there is a "regional carrier" in your area, that needs a runner, but the same thing, again, slow freight times.
i'd dump all those vehicles you really don't need, even that mack, if you do buy a sleeper, and bank that money, or at least pay down the "newer" sleeper.
easy advice, but you do you, with good luck from me.
"All those vehicles"? 🤔
yeah, don't you have like 47 cars, trucks, suv's sitting around.>??
you used to at least.
Meaning, if I've been following the bouncing ball, you have 4 vehicles. Not talking scooters or golf carts. Two Class 8 trucks and 2 passenger vehicles.
yup..i think he had some sort of Pontiac, a ford suv, some others i am trying to recall. (ah, i recall) a ford f-250, and a ford escort..he had a trailer that he had behind the f-250, to take home the ford suv.
then his 2 big trucks.
I currently have the 1986 F250, 1988 LTL9000, 1997 Escort wagon, and 2014 Mack.
Neither POV is going anywhere. They're too useful and not worth life changing money to sell. The F250 is a dead simple, dead reliable vehicle that will probably outlast me. The wagon will be run into the ground and scrapped, but is reliable in the meantime. It is also more comfortable and economical than the F250.
The LTL can go if someone makes an offer that's reasonable.
The Mack may or may not sell depending whether I swap parts and/or put a driver in it. But there's no emotional attachment to keep it. I'm just not going to have ratty wheels and almost dead tires on the sleeper and let the Mack go cheap with perfectly good ones that I could use.
I also sold that open deck trailer during covid. I kept the enclosed one as a shed for my mowers. My garage is too small.
That trailer could go if I ever get my shop built. It probably should anyway since it would be tougher than it already is getting in and out. In the meantime it's too useful.
5.8mpg in the storm Friday night and 5.9mpg in the sub freezing frigid temps last night.
Still pretty darn impressed for what it is and compared to before. I'ma call it BF for Before Filter and AF for Anno Filtri aka In the Year of Our Filter.
I used to make excuses for it getting less than 5. Now I'm making excuses for it getting less than 6. So that's an improvement.
That LTL will bring you about $40k-$50k down here. It would off to the islands before the ink on the paperwork dried.
They can't get modern parts and almost no one has a computer to diagnose what's wrong on a newer truck. Pre-DEF trucks are worth a small fortune.
That would be nice. Put out the signal.
Did tonight's load last night because last night's load didn't have a pickup number or a chassis assigned to it. In my experience that means it didn't make it to the rail.
Well coming back, I dropped my empty at the rail and happened across the load. It's on a chassis where they usually have inbound empties, and they never updated the system.
So I have to let my travel agent know about the switcheroo and it's existence after all.
Debating whether to run tonight if she says to, or just take the rest of February off.
Truck has some gremlins that I need to fix anyway, and a warm enough day is fleeting if it comes at all. Really don't want to try to fix it under pressure.
Plus my taxes, cardboard disposal, and general burnout again.
Put in some job applications with companies within 10 miles. And by some I really mean two. One is a grocery store and the other an LTL that uses mostly 53s. The LTL company had a section for owner ops on the application so I filled it out too just in case.
