It just occurred to me earlier this AM that my DEF filters are about due. 150k is the prescribed interval and I'm right about there now, give or take. The one is the filler neck and the other is a cartridge in the DEF pump. I can see the latter being the cause of my recent derate threats and then ultimately a forced parked regen since it was accompanied by a DEF quality message.
If it doesn't like the DEF quality, in theory I suppose it could also retard the timing or some such other EGR trickery or something that would reduce the amount of NOX produced and therefore give me worse fuel economy and/or the feeling of lack of power.
So I'm gonna get my ass right on those filters to see what happens.
Hopefully there's no white powdery crusty stuff in the system 😳
Well that's done. It's super easy. But $183 for this. 🙄
The butt plug looking thing on the far right goes inside the paper filter to seal the cap. The far left is the filler neck filter. The black thing laying down is a removal tool for the paper filter since it's shoved way up inside.
I was going to try an aftermarket one but figured it's not worth a chance being the after treatment system. Even at this price it's only fractions of a penny per mile.
Having said that, now that I have a part number I can cross reference to Bosch, which is significantly less expensive and the OE supplier.
Macks are like Harleys. The supplier is cheaper but when it has the name on it from the dealer, it's stupid expensive.
Here are the old filters. The neck filter could probably go longer but it was definitely doing its job. The stuff that's on the outside of the neck filter is because I laid it in a pan with debris. But there is definitely crap on the inside.
I probably won't start getting 14 miles per gallon, by the way. I saw some videos where the little bit of def that leaks out was all brown and gross with rust or whatever. Mine was pretty clean. Surprisingly clean.
They were all Volvos though so they probably went way beyond the interval. Probably only discovered the filter was a thing at like 800k.
I only made this post so I'd get more likes from @AK7. Onlyfans link to follow.
Realistically it probably won't even save me 13 seconds because I'll probably forget I have a 27mm socket and won't be able to find it 3 years from now. But it makes me feel better.
Or, knowing me, this truck will be long gone and the next one won't even have the same filter arrangement.
Thought I cancelled the aftermarket filter in time but alas it's still coming.
Not sure whether I should return it or compare it with the old OEM and hope for the best 3 years from now. It was less than $20.
Truck runs smoother and maintains speed better and fuel mileage is up. Pretty much back up where it was when I bought the truck.
I'm going to shorten the filter interval to about 100k if I remember to. This thing was running so poorly with such shit economy I thought the EGR cooler failure had done permanent damage and it was on a rapid descent to the scrap yard.
don't you keep a "log book" of all things truck related?
i keep a log on my cars, and my guns.
knowing how many rounds thru the barrel, factory new ammo, or reloaded ammo, cleanings and dates of range trips, makes me aware of what gun is next to go shooting.
knowing when my oil/filter and tire rotations were done, keeps me up to date on PM services.
rather than to rely on memory
I used to then started writing down on the receipts themselves that are stored away.
It's a bad habit and I need to get back into my centralized logging.
IOW know when I did everything and how much it cost but I'd have to dig it up.
If I had done it myself I'd have the memory for when I did it though.
My remembering next time won't be for the filter itself but it'll be for the shorter interval.
The closer interval stuff like fuel filters, I sharpie it directly on the filter cartridge under the plastic dome. Diesel doesn't wash it away. It's not really an interval though. When it's full, I replace it. I just like to know how long I got out of it.
7.2MPG on the new tank trip, which was the empty leg up from VA to the Yard then bobtail home.
6.3MPG on the entire day trip, which was loaded down I81, down 522, across 55, then down 11 the entire way into Bridgewater, then the empty back up 81.
On 11 I seemed to get almost every red light and a bunch of school buses stopping to let kids off because I'm a dumbass with my timing some days.
Anyway, I was at 5.2 when I climbed onto I-81 here in Chambersburg with the load, then 5.7 by the time I got to Bridgewater.
For as much accelerating I had to do from a stop or near stop on the way down I was impressed. Last time I did this run the same way I didn't have hardly any slowdowns on 11 and couldn't even get 5.8 on the whole trip. Towards the end of the old filters I was getting low 5s even running slow.
I write the date and odometer reading on oil filters on the vanmobile and Blueford.
I don't know why I do it on the van though. It's not like I crawl under the van periodically to look at it.
Blueford's filter is clearly visible from the top. But it gets driven about 100 miles a year so...
It's funny all the vehicles I've had prior I OCD'd my records. I haven't recorded a single thing for the wagon for round 2 of ownership and never bothered for the pickup.
I don't know if it's because they're beaters or that I almost never drive them or what. But it just didn't seem important to be on a schedule with any of it. I don't think the odometer in the pickup is even accurate. The speedo definitely isn't.
Having said that, the wagon has been pretty good this time around. I did all the stupid excessive things last time when I was poor(er) so this time it's only been 2 new tires, LED headlight upgrades, EGR valve, and the new radiator. I also cleaned the EGR tubes.
Only reason I don't write on the Mack oil filters is because you can't really see them from just peeking under. The fuel spin on is kind of the same so if I don't write on it it's because I already wrote on the davco and they get replaced simultaneously.
I don't really worry about doing the oil at *exactly* 45k or whatever anyway. As long as I'm close. I'm gonna choose the most convenient day near it to get messy anyway. Not like I schedule it anymore. Just have to have a decent day and/or be in the mood when it's not a decent day.
Today was a mixed bag of inconsistency fuel wise. Abnormal behavior on my part.
Started out meeting a new driver at the rail. We idled a bit and he asked me about some glad hand problems he was having.
Then I idled a little more to get a mud flap replaced.
Then I idled more to wait for an empty trailer that @Rigjockey never brought so I bobtailed out.
Then I bobtailed home.
On the day I got about 7.5mpg and from the same fuel location as yesterday I got 11mpg bobtailing up at 65-75 and mostly 68mph.
So definitely not a typical routine day.
Noticed my voltage is up a few tenths on average. The old filter was creating resistance for the pump so it had to work harder.
I'll probably start doing these filters annually. At least the cartridge. Maybe not the filler neck filter.
I had no idea this filter would have such a huge impact on performance.
