So I have this theory that finishing up tonight at 10pm means I can actually get my slug ass rolling by 8am tomorrow (an exact 10) then finish up in time to get a 34 in by 2AM Tuesday.
My hypothesis will be proven incorrect, I'm sure. But I tried by entertaining it. That's all I can ask and expect of myself.
Fortunately, I've trained these people to expect the very least of me, so I don't HAVE to be up at 2am on Tuesday.
Clarification: I have trained them to give me gravy loads with no requirements other than getting there at some point probably.
I have always thought they were hideous anyway. I tried to sit on one on a showroom floor once When I couldn't even get my foot past the passenger seat that was just one more reason for me.
There are a lot of decently powerful bikes out there that aren't 7 8 900 lbs. That kind of weight you're usually talking a touring bike of some sort and a sensible person that's never really ridden a street bike shouldn't be starting off that big anyway.
We've got a 750 that I started on that's 400lb and change. My wife rides it now. That thing is night and day to my Road King on the highway and a few other scenarios. I think that has more to do with the narrower tires than just the bike itself. Personally I don't think highway riding is that enjoyable regardless. Riding isn't usually about getting there the quickest way possible and sometimes there isn't necessarily a "there" that you're aiming for.
that is why i really liked the Harley's..no matter the size, one can always in into it, rather than on it.
but the price tag, dealer network, and whatever assorted problems they have.........was a no go for me.
Japanese bikes were the way to go, like most cruisers or baggers.
Trying out 1080p. Sometimes a good 1080 is good enough compared to the logistics of 4k files. I also read that the camera uses the entire sensor for 1080p but only a cropped section for 4k. You'd think it would be the other way around.
I've seen "HD" cameras that are supposedly some huge pixel dimensions but the image quality is crap. It's like they simply took a 640x480 image & embiggened it, rather than having a lens & sensor capable of capturing the full size optical field.
But because it SAVES the image in large pixel dimensions, they're able to claim those dimensions.
It's false advertising.
Pretty much.
I've tried 1080p and it's okay but not great compared to the 4k so I'm sticking with 4k. 30fps instead of 60 is a decent compromise though to keep file sizes manageable. Still not keeping junk videos since they waste a lot of storage.
Pretty much.
Anything above 30 fps frame rate is unnecessary anyway, unless you want to slow-mo the video without it looking animated.
I have a Minolta DiMage Z1 at home somewhere.
Hopefully with no batteries in it. 😳
It's nothing fancy like your stuff and I forget how many MP but it's got a 10x optical zoom. And digital zoom but that's artificial enlargement so it doesn't count.
It'll record 640x480 video at 15 fps or 30 fps. I used to keep it set at 15 fps because memory cards weren't 36 cents for 800 terabytes yet. I think my biggest one was like 8 GB. Whatever the max size supported by the FAT32 filing system was.
60fps is smoother without that jittery blur when the camera itself moves. It looks better to me. For objects moving in the frame it doesn't seem to make a difference. I run my dashcam at 60fps since the truck is what's moving.
Welp it's official. In order to maintain perfect balance on the gimbal, I have to forego my shotgun microphone for now.
It needs to be mounted somewhere on the handle because equilibrium is impossible with it on the camera.
I'd probably be able to keep it there if the camera wasn't so big. There isn't enough room for adjustment since the camera by itself almost maxes out the gimbal.
I made some new 1080p 60fps night footage to directly compare with the 4k and there's definitely an obvious detail loss. Not so much in the cars passing but in the buildings like the brick and porch columns.
I have fetishes deeply rooted in OCD therefore I will probably continue to use 4k. I will spend stupid money on storage drives and software and such but my eye will not twitch.
It's not like I'm producing 12 hours a day of porn, unfortunately, so it'll be manageable.
Had an ah-hah moment and with some electrical tape and futzing managed to balance the camera with the mic mounted on top.
I lost some vertical tilt because of clearance issues with the weights hitting the pan motor but I lose vertical tilt in the opposite direction with the mic hitting the rotate motor so it's not really a big deal. I mostly just want smooth, level shots while standing and the clearance issues are more at the extremes.
So I discovered I can program movement limits in the gimbal to prevent the mic and weights from hitting when I use the joystick.
Also discovered that the three modes are customizable. I suck at panning slow, so I set the speed on mode 1 super slow with max joystick input, and deprogrammed the tilt so that I can't accidentally screw up the level. Did the same for mode 3 except made it super fast to follow a vehicle.
Middle mode is now basically normal with up and down and pan limits so I don't accidentally get myself in the shot or bump the aforementioned weights/microphone.
This thing is way slicker than I originally thought.
