Electric Chicken
When I bought the LTL it didn't have a reservoir for washer fluid, and it had a foot pump near the high beam pedal. Being a shorty I knew that wouldn't work out even if I got a reservoir.My dad had a 1970-something Datsun when I was a teenager and it just had little copper tubes sticking up through the vents in front of the glass. The ends looked like they had been crimped over a piece of wire or something to create the jets.
I bent them forwards and surprisingly it had enough pressure to soak the rear window of the cars in front of me at red lights if I was close enough.
I bent them back and forth too many times & they broke off.
After they broke off, they worked even better than before. They'd throw more fluid but not at high velocity.
I went online to VanderHaags and got an OEM under hood reservoir from a newer model (might have even been an L9000) with electric pump and wired a push button on the dash.
I screwed it into the firewall and a cab frame rail near where it was on the donor since there really wasn't an OEM provision on that truck. Fortunately it came with the bracket.
Come to find out whoever resprayed the truck clogged the jets with paint.
I don't remember what I used but I had to run a wire in and out to clear them.
