Guess that depends on what kind of defects you're finding. If they're that major you probably shouldn't have a DVIR done at all. By this point you've already refused to pull the trailer, no?Yeah it's a samsara. You can mark minor ones as safe to drive.
But if you can't mark unsafe defects what's the point in doing no defects or safe defects.
Do it right or don't do it at all IMHO.
You've never pulled a trailer that had OOS defects by the time you dropped it?Guess that depends on what kind of defects you're finding. If they're that major you probably shouldn't have a DVIR done at all. By this point you've already refused to pull the trailer, no?
I wouldn't put a recap on my lawn mower.Fortunately the rail isn't fighting me on replacement. They used to argue anything still holding air couldn't be replaced.It's very plain to see the gash. Add some weight and road heat and it would surely have the potential to blow. Plus, it's a damned recap. Those things ought to be illegal.
These idiots down here run recapped super singles on tankers!I wouldn't put a recap on my lawn mower.
More power to you.I guess I have too much "outlaw" in me.
I once drove a freightliner from Chicago to Kansas City with a sloppy loose left side steer hub bearing.
I knew something was wrong because of a noise it would make when side-loaded on a curve, but I completed the run and didn't find out it was sloppy loose until I got to a shop in KC and they jacked up the steer axle and I grabbed the top of the tire and the whole wheel wiggled side to side.
Another time I drove a truck from St Paul to Milwaukee with a blown power steering hose. My arms & shoulders were sore for 3 days after that.
I kept a reefer unit running on jumper cables from the truck for 4 days when it's alternator went out and the schedule was too tight to allow shop time. I had to be careful turning corners or it would pull the cables loose.
I had an electrical short in the wiring harness on a Volvo but I was in the middle of a snow storm at the ID/MT line, not far from @Injun territory. Drivers side headlight socket had no power available. I discovered that when I was looking at my truck's reflection on the back of another trailer with stainless steel doors, at a scale house entering Montana from Idaho, and I got through the coops simply by turning the headlights off, which is a courtesy we usually do at scale houses so it wasn't suspicious at all. It was in that scale house lot, post-scale, where I stopped to change the bulb (I had a spare) and discovered there was no power to the socket.
I used spade terminals, speaker wire and a CB radio cigarette light plug to power the left side low beam from Missoula, MT to the yard in Iowa.
I've attached mud flaps with zip ties, but I think everyone has done that.
I had a ride leveler valve linkage break in a way that required welding, but I just used a ton of zip ties to hold the valve actuator lever centered to keep it inflated from Virginia, through 3 drops and one pick, requiring cutting and replacing the zip ties each time to compensate for weight removed/added, then all the way back to Iowa.
One time I had the pneumatic trailer axle slide lock valve freeze up at the Walmart DC in Menominee WI where @Sinister worked, and they were stuck in the unlocked mode. When empty, I left them all the way back and drove with the blue line disconnected so they wouldn't slam all the way back when I hit the brakes (if they scooted forward for some reason), for about - I forgot how far it was - to a Mills Fleet Farm in or around Hudson, WI where I bought a propane torch and thawed the valve.
I wouldn't be afraid to make a local/regional run with a piece of metal stuck in a trailer tire.
Hell I've probably run tens of thousands of miles with impaled trailer tires as long as they were holding air I didn't give a shit.
It'll be known by whoever's paying the bills but odds are I'm not doing another DVIR if I'm already done with it.You've never pulled a trailer that had OOS defects by the time you dropped it?
The same day I called in the tire I called in the one I had just dropped because the quick release valve or fitting was leaking. It wasn't when I picked it up, I drove straight down with it not stopping, and never had any ABS lights. So at some point perhaps when I finally got there and hit the brakes for the last time, it gave out. I'm not going to say that's safe to drive. Maybe it is but this is a CYA industry anymore.
Again, if you're not going to DVIR the worst ones, why DVIR the ones that aren't a big deal? They want a DVIR for everything. You're telling me to knowingly DVIR an unsafe as safe or mark it no defects? Nothing would ever get marked as unsafe even or especially when it obviously is.
I'm not going to be inconsistent. Then none of my DVIRs are trustworthy.
Yeah it's a different thing here.It'll be known by whoever's paying the bills but odds are I'm not doing another DVIR if I'm already done with it.
Bare in mind I've never worked for a "mega" as it were.
i thought the idea of being an o/o was to get away from the day to day micro-management bullshit of a company?Yeah it's a different thing here.
All the "I would never" doesn't fly. They can and will simply cut your ass off and you don't run anything until you comply.
This same woman sent another threat about certifying logs every day. She loves to block people.
Yes, I know it's to be done and I do it, but she's on a power trip.
Yes, it is. And it sucks to be in this situation.i thought the idea of being an o/o was to get away from the day to day micro-management bullshit of a company?
if so, then you put yourself in that situation.
didn't you have better hauling "contracts" with other companies?
I can't wait til you line up a better carrier so I can read your final email reply to that obnoxious woman. It oughta be good.Yeah it's a different thing here.
Yeah if the market was still hot I'd go get my sleeper and be done with it. Unfortunately it's cooling off, and going elsewhere could be a recipe for disaster at the moment. I know what I've got here, and I know I can use my truck until it's all used up. I'm not going to let one person dictate my success or failure in this industry. I'm also not going to run from her. She tried to have me fired before and her boss didn't let it happen.I can't wait til you line up a better carrier so I can read your final email reply to that obnoxious woman. It oughta be good.![]()
Yeah DVIRs are for the condition at the time of parking it. It's to alert the company that hey this thing needs something but I got it here.^^^ This is kind of what I was driving at with the DVIRs and getting things fixed. Just a couple weeks ago I had a completely flat inside drive tire for whatever reason when I came in. Called the boss and was told bring it to the main yard (a couple streets around the corner). They already had a tire on the rim and knocked it out. That never made it to a DVIR
The blocking dispatches trick wouldn't really work for a company driver. When it's their truck they actually lose out when it sits and you know the bean counters can't have that. At least the c u next Tuesday can't kick back paper logs because she doesn't know how to do math or know how sleeper splits work. I've been down that rabbit hole.
She used to say I wasn't taking breaks when I needed them. She'd say I was in violation even though the software already checks for that and knows when I do and don't need breaks.^^^ This is kind of what I was driving at with the DVIRs and getting things fixed. Just a couple weeks ago I had a completely flat inside drive tire for whatever reason when I came in. Called the boss and was told bring it to the main yard (a couple streets around the corner). They already had a tire on the rim and knocked it out. That never made it to a DVIR
