I've got them rolling in the medium grit now. Spent about 8-10 in coarse the first time, cleaned them, then another 8-10 in new coarse. Didn't really make them better than the first run so I can skip the second run next time.
Now I'm on run 1 with the medium. I'll probably skip a 2nd run and go into the polishing, one run each. I'm curious to see if they'll actually shine. As of now they look sandblasted.
So, buddy goes in the exit only and then has to back out into the street and then buddy has the proper entrance on the right but makes a left into a completely different place? :headscratch2: :dunno:
He'd have to back up like 200 feet. Based on that video I don't think he's capable.
The "entrance" immediately to the right of the exit sign on the street view is for cars. And I'm pretty sure it's also an exit only.
I'm going to give another pair of centramatics a go. I narrowed my bobtail death shake down to most likely another lost wheel weight. I was thinking I didn't see one when I took the old centramatics off, but it's dirty so I didn't think a lot of it at the time.
The left steer has a 3-4 second on and off again consistent vibration at 65mph on Cruise and shakes the shit out of you at the proverbial 55mph. Once I found a good enough stretch of road, I was able to count the vibration in my head. 1234 vibrate. 1234 vibrate on and on non stop. Then like clockwork, slow down into the zone and shake your fillings out.
On the way down I had 40k in the box. First time ever, or at least in a long time. It rode pretty decent with the weight but I could still feel the steering wheel go back and forth a little, which also told me it's balance.
The centramatics were awesome when they were new, and I seem to constantly lose balance weights so I'm not going to keep having that done.
If it's a CODB, so be it.
Here are the fasteners I want to clean up next. I'm going to replace them with new anyway but this is what really gets me curious about the tumbler. I'm going to use flange bolts and nuts. I'll never understand Mack's decision to use regular bolt heads with no washers, and nylon lock nuts with no washers on the other side.
Not much is happening with the rock tumbler after a day with 600 grit, so I cleaned everything off and now it's tumbling with Dawn dish soap.
I think the problem with nuts and bolts is that at a certain point you're not actually polishing, you're just removing more metal. The tips are already rounded off, making it less easy to start the nut.
I don't know if I should have just started with 600 grit. The 60 or 80 or whatever is probably what killed the ends.
Cleaned the nuts and bolts off after the dish soap bath. Figured that doesn't need to be an all day process.
Chased the nuts onto the bolts to fix and make sure the threads still worked smooth (they're butter), now they're in for a 1200 grit polish to see what happens. Hopefully the threads are still smooth, and the hardware looks better as well.
Maybe I'll mail you these big eye bolts if I can get 'em out.
That beam sticking out of the barn for the hay loft trolley has been exposed to 106 years of rain, sunlight, snow, bird shit, moss growth, freezing temperatures, ice lamination, etc and this is how good it looks after about 5 minutes with a nylon wire wheel in the drill.
I'd REEEEEALLLY like to know for sure what type of wood it is.
The guys on the woodworking forum suggested white oak.
Here's the "before" pictures from before I started cleaning it up.
The barn was built in 1917.
The plan is to grind a slight crown into the top like a road, so the rain rolls off the sides, then sand it smooth with various grit levels in the palm sander, then paint it white and mount a fake eagle on it.
My rock tumbler won't hold those. It's only about 5 inches across.
Looks good :thumbsup:
Now do the rest of the barn 😁
I think you’re right about the white oak. I was gonna guess red, but I did some readin and red dont have the durability what you got there woulda needed to hold up this long
Blocked another one in this morning. They're like cockroaches. Squish one and 10 more show up.
We're adjacent to a federal government installation, on part of a former army depot. I have some ideas, I'ma tell ya what.
Blocked the same one in again this morning. Someone pulled my previous empty out so I put mine from this AM back in.
