I forgot where you said you got the cheapo ones from. Amazon?
The first cheapo was Amazon for $175. The second cheapo was eBay for $37.
The only reason I paid what I did for the Amazon one was it had Prime next day delivery. I did not expect the eBay one to show up only one day after that.
Nor did I expect the Amazon one to fail at something as simple as an air fitting.
Made in China.
Check out this little piece of proud Chinese engineering.
This is one of the exhaust manifold studs from Sarah's minibike, that held the muffler on. The other one is in the yard somewhere.
See that black stuff? That's what happens when you put nylon lock nuts on something that gets hot.
Yeah the geniuses over there in China put locknuts on the exhaust.
:bonk:
I took it to the hardware store and found two new metric whatevers to replace them, and I used regular nuts with split type lock washers.
Muffler ain't fallen off since. And my dad rode it wide open for 14 miles.
Made in China.
:bonk:
Yep. The second also Chinese. Good air fitting but sketchy fuel input threads.
Can't win. 😂
Kinda wish they'd just tap the air input and let you add your own fitting. If I could successfully yank out the one they pressed in there, I'd do that myself.
Took the cardboard to recycle, got gas in the car and filled both cans for the mower, and now I'm waiting for the UPS Store to open because I'm a little early.
Thought I'd be waiting in line at the landfill but it was quiet.
Before I left I fired up the truck again and looked it over. It didn't give me any lights or warnings on the dash so I told my travel agent as far as I can tell I'm good for tomorrow.
UPS done, swung by the Post Office to empty the junk out of my box, now home. Put the gas in the garage for now. Nap time until Aldi texts me that they're done shopping then I'll go fetch the groceries.
I'd mow but it's a little too damp for my bagger, so that would be more hassle than it's worth.
Glutton for punishment/curiosity killed the cat. I have yet a third cheapy module here. Decided to pull the air fitting apart. There was no o-ring in it. I suspect that was the case with the other cheapy as well, but I never bothered to look before packaging it back up.
The second cheapy definitely had an o-ring. That's the one that's on it now.
I pulled one of my unions apart and stole the o-ring from it and put it in the third cheapy.
I want to see if I can actually have a success rate with these before I go blowing $600 on each one from the dealer. Having one in my inventory will curb the downtime, if it works.
I mean I'll get a supply of o-rings if that's the only difference.
Thought I had it all buttoned up but the aftertreatment injector stuck open code/fault came up again. It's a code that points to a fuel leak somewhere for the DPF regen but I see none, and I replaced the 7th injector with an OEM this morning and that didn't solve it either.
The only thing I can think of is rip this second cheap module off and reinstall either it or the next one with the new banjo inlet gaskets I bought when I got the injector.
Or say fuckit and go down and get an OEM module.
Maybe I contaminated my install not bad enough to visibly leak, but enough to introduce unmetered air and reduce the pressure.
There aren't many components to this thing so it has to be somewhere from that module to the 7th injector.
Replaced the banjo bolt seals. This time the threads were easier going in. I must have gotten one of the seals bound up and was working against it going in last time.
Still doesn't make the computer happy. It keeps triggering the seal/leak code.
I find no leaks anywhere so I'm only guessing here but perhaps yet another defective module.
I have another cheap one laying here. Debating whether it's worth the effort. I've got it down to being relatively easy to swap but that doesn't mean it isn't annoying to go in there a bunch of times for the same problem.
The only upside to this is the original code was stuck closed. So that one is fixed at least.
The other alternative seems to be that the fittings aren't sealing quite right on the line from the module to the 7th injector.
I don't see or feel any leaks though. You'd think any kind of leak at all would drip at least a little something eventually.
I've got new compression ferrules coming so I'll see if replacing those does anything before I replace this module...again.
Haven't made much progress on the truck. Since it threw the code again Monday I've parked it to avoid a derate under load. I remember how miserable that was when it happened at pumpkin, and I don't even have a clutch to feather to trick it this time.
Anyway, I have the new ferrules & inserts and await a new diffuser because I'm thinking I'll just do this thing wholesale all the way through hopefully once and for all.
I would get the new steel tubing too but I don't think that would do me any good since it's not a clog I'm dealing with. Fuel is flowing, it's flowing too much somehow.
The diffuser is a section of exhaust that the 7th injector bolts into. Maybe the old one is too pitted to seal properly anymore. I don't know. But I'm annoyed with it all at this point.
Downtime is downtime regardless, and doing it myself is cheaper than having a shop do it plus the downtime.
since the aftermarket part is throwing that code, it reminds me of some aftermarket parts i used when i wrenched...NAPA, Eichlin, Mighty, Niehoff, were parts companies that would produce ignition parts back in time, and they NEVER had all the correct specs as the OEM parts ever did.
i had more shit issues with electronic ignition modules than ever, using them.
once i started using OEM (read expensive parts) all problems were solved.....
not too many if any at all, aftermarket parts are exactly made the same way as the OEM's are. that's why they sell so cheaply.
just saying.
just saying.
Don't know for sure the aftermarket is throwing the code. It's throwing a code for an unexpected condition, that may or may not be the aftermarket part.
Probably is, but I'm still in denial.
So I said fuckit and ordered a new OEM module, supply lines, and gaskets from the dealer to just replace it all at once.
Didn't ask how much it's gonna cost but I'm not even going to waste time with these cheap models, especially if the problem is actually in the connections themselves.
If I replace only the lines, I might as well have them buttoned up nice and tight to a new module in case it was actually the module, because taking it back apart to replace the module would compromise the integrity of the connections.
The module isn't cheap but the downtime is going on 2 weeks already. I used it to clean my house, and have plenty left to do, but can't go without income forever.
Crawling under for the same problem over and over is also getting old.
The fuel lines are going to be a pita since they wrap around the back side of the engine. You know...where it damn near touches the firewall.
I have to look again but I think the doghouse is real and can come out. So I'll probably be doing some of it from inside the cab.
For now I'm pre-coping with a little jack & coke. I already know it's going to hurt.
