Made some lifting blocks with carrying straps. They hold onto the frame with deck plate brackets. Sometimes people drop stuff too low. I figure dump the air, slide these on, back under, and reapply air.
If it's too high, dump the air, add even more wood, lift, crank handle, set down, remove wood, then hook.
View attachment 88079View attachment 88080View attachment 88081
I do that when they drop the trailer too high.
I dump the air, add some 2x4's and raise the air. It raised the landing gear off the ground and easy to crank.
I'm kidding. There were tornado warnings a few miles away earlier. We had a pretty good rain storm. I think they're over now but at this point I'm just lazy, and the damp weather isn't going to help the paint dry anyways.
Mine has a steel plate all the way across the top of the frame. I keep some short 2x4 and dunnage pieces because I have to do exactly what you're describing way more than I care to.
Some guy (not a driver) saw me doing it a couple weeks ago and says "You didn't just fall off the turnip truck did you?". No. No, I did not 😅
One place I was working at driving the yard truck...Driver come up to me and says you're dropping the trailers too high.
Dude, I don't even touch the landing gear, what are you talking about?:bonk:
I have no problem with helping a driver with a trailer dropped too high, but don't blame me for the way the trailer was dropped.
We've got one place we pick up "preloaded" trailers that are not ours. They have a shunt truck. It was down in the shop for a week or two and they had a crapcadia day cab rented from Ryder in the meantime. EVERY single loaded trailer break out the lumber and believe me it was more than mentioned to them once or twice.
I dunno maybe at least TRY to drop them too high for you since you're done with them at this point and all ours are tall. I was in there this morning and I saw the shunt truck was back. That was a big relief.
Honestly, I should have done this ages ago. I've been cursing under my breath for years.
We all have different trucks so I wouldn't be surprised if no two of our trucks have the same 5th wheel height. I seem to be one of the lowest though. I'm always backing under chassis that are about an inch too high.
