$416 later I have my truck back and the pull to the right is gone. It was a caster issue in the right front. They put in a wedge and made it perfect.
Everything else has been checked and cleared as a-ok or adjusted and set with a couple things to further investigate/watch.
The kingpins are within spec but they aren't perfectly tight, so they're keep 'em greased and bank some money.
The shakes MIGHT be caused by the transmission output bearing that on this truck doubles as the carrier, which has movement designed into it. I've had it checked before and Mack said don't worry about it. But I might have them replace it anyway. I'm going to get the GoPro down there to see if it picks up anything now that the rest of the truck has been deemed good. It could simply be a design issue that's exacerbated by our roads. It seemed to smooth out when loaded heavy even before this, and mostly be a bobtail/light problem.
I'm just happy to have it narrowed down, even if it needs transmission work in the near future. Glad to know I'm not crazy, it actually did pull, actually does shake, and wasn't just the roads/trailers.
The stupidly ironic thing is if I had these folks put that wedge in 2 years ago I probably would have saved like 10-15 grand on chasing and untold downtime. 🙄
Maybe one of my new policies should be to take every new to me truck to these guys for an initial shake down.
They should have replaced those U-bolts
Up and down 81 today with 2 slightly dog legged trailers. Neither of which affected my straight line much. Could actually let go of the wheel and still roll straight at 70mph. Never was able to do that in my entire ownership of this truck.
Seriously though 75 is my ECM max because of the tire rating, and I confess nothing but it felt nice compared to...every day since I bought it.
I'm not saying it doesn't still need shimmies and shakes squared away but they're VERY minor compared to what I had before, and the pull is only slight from the misaligned trailers trying to get out of the groove. It's not the tug of war that it used to be.
I finally feel like I could run all day again. I won't, of course.
A 12 speed with a final drive of 2.94:1 and 75 is your max? What's 12th's ratio? Should be about .75 or higher. (lower number) I would think at 1800 you should get 84-88 out of it.
ECM max. It's governed because it has 75mph tires on it and I've never bothered to spend money on faster ones and get it opened up.
2.47 rears. It only turns about 1325 RPM. It's barely getting started.
I was told it's 2.47 but it might be 2.7 or 2.75 or thereabouts after punching it into a calculator. They might have meant 2.74.
That same calculator says it'd be a 99.9mph truck at 1800RPM. At 2200 redline, 122mph.
Finally fixed the power wire for the backup beeper with a brand new eyelet and pretty shrink wrap and everything...and the stud broke off the beeper internally. :rolleyes:
Amazon has figured out how to outsource the check in gate. You pull up to an intercom and a thick accented middle eastern person garbles at you from a busy room full of other thick middle eastern accents.
It doesn't help that they always seem to have headsets that were freshly dipped in water. It's almost like they store them in a fish tank.
New backup beeper installed about an hour ago. I'd share a pic but @Duck will just find something to criticize.
Also had to get groceries again. Last time was exactly one month ago so I guess that's not too bad. :rolleyes:
Nothing much going on at the rail so my travel agent had me set to fetch empties tomorrow out of York. She said they're already empty and waiting so I can get them anytime. I'm going tonight since there wasn't anything to do today, and this will free me up in case some real work drops in tomorrow.
Plus it's easier to get to and maneuver around York at night than during the day. I know I said I hate nights anymore but I'm on a high from blindsiding at night at Amazon PHL6 without hitting anything important.
