Getting rid of them.
Those were your words. Did I not quote you.
Ok, ok I'm just being, like UB would say, fictitious.
I'm not seeing anywhere that throwing away perfectly good tires was mentioned until you recommended it.
You quoted me saying I have good tires on the Ford and you said throw them out.
Not that it matters. I just finished installing new Michelins from STTC. They didn't have 295/75 so I had to get 275/80 or whatever they are. Same diameter just a slightly narrower tread.
The relevancy is that I don't trust tires that have sat out in the weather to be on my steer axle for a coupla years. You do as YOU see fit with your truck. My life is worth more than $1500. To me anyway, not sure about others and don't care. I go through a set of steers in 100k on these coral rock roads and airport ramps.
If they are smaller in diameter, then you can ride up the road with your ass in the air. If they are larger in diameter, you can ride up the road with your rear squatting like a girly redneck pickup squatting to pee!
Your entire truck sits out for years... including the tires.
Age out is up to 10 years. 6 or less is recommended. 2-3 in mostly shade is basically nothing.
Day 1 with the new tires yesterday. Some of the shake is gone but I have a pull to the right now that I think was being masked by the old tires, because I didn't change anything else.
My kingpins and bearings (yeah the new ones) are solid and quiet. I didn't suspect those but figured it was already in the air so checked once more just to be sure.
I remembered when I replaced the slack adjusters that the passenger side had one of those too many shims is tight, take one out is loose issue. I defaulted to too many back then but thought maybe it's dragging the brake sometimes, which would tug the wheel. I took one of those shims out. It doesn't feel as loose as I remembered when first installing. I haven't driven it today to see if it helped.
All the shocks are new OEM this time around.
Other than that all I can think of is I need another alignment after all that beat up time on 78. It's hard to really emphasize how bad those roads have gotten, especially the right lane.
Just get that alignment done in the next week or two before any wear patterns start.
Good alignment shop, not a truck stop or dealership that blindly adjusts to green colors on an alignment machine.
Look for an MD alignment shop around you.
So I'm at Unilever and the loads are always stupid heavy basically the same as P&G.
Anyways these dudes with tall rubber always drop trailers a couple inches too high for my 5th wheel. So instead of cranking myself into a heart attack, I flagged down an SAE @Rigjockey.
He says sure I'll lift it but do you live down there in *my town*? I said yeah why? He says I do too. I pass your truck every day. I live a couple streets down and over.
I'm like small world. He's like yeah.
I'm kind of small town famous up in this bitch.
Anyway saved me a shit ton of effort. It was 45250 in the box according to the BOL. 😏
Got an appointment with the chassis shop that rebuilt my Ford interaxle driveshaft after it snapped in half. They did me a solid and got it done next day despite being booked up.
When I called this morning they said they were booked into mid June. Then they said they could look at my truck on May 16th if I drop it off, and work whatever it needs in the following few days.
These guys actually build trunnions for Mack camelbacks. They're a chassis/manufacturing shop that really knows their shit, and educated me on the Neway air suspension on the old Ford.
They can also bend axles for camber, and they set everything to zero, not just within spec.
I'm confident they'll figure out what's up with my truck.
Almost ordered the Snap On SOEXM710 and SOEX710 wrench sets off eBay. Good pricing for the kits compared to SO direct, and brand new.
Then I realized almost everything I work on anymore is bigger than that. 7/8 biggest, really? 19mm? Come on. I'd be buying individual wrenches anyway to expand the nearly useless set.
Maybe when I'm drunker. 😏
I was doing some research maybe six months back when I was looking at Snap-On tools. I came across an article about the decline of being a Snap-On salesperson.
The reason was, mechanics only bought Snap-On tools because they would be delivered. Now days there is a Home De-Pot or whatever on almost every corner, so they just go there.
I am not trying to tell you what to do with your hard-earned money, I am just saying what I learned.
