Well I did drop the F bomb a couple times.
When the cameras were first put in our trucks, because it was a new thing to the office idiots, they had to watch them. We've had the block on the driver facing cameras since day one. But, the audio was always on. The bosses put out a blanket email to all of the drivers stating that the language being used when drivers were cut off or other stupid things were done was over the top and please refrain from it. A month later, they just turned off the audio and gave up on the cams unless a hard braking occurred or a quick move reaction which triggered an alert. I was claimed as the worst of the group. They said I would have a heart attack by the way I screamed in the truck at people.
The Omnitracs ELD has a hard braking setting and they email the driver when one is detected. They only sent me one email and my reply was, "Look at your camera and you decide if I acted correctly". I haven't heard from them in a year now, except for the time a big black wild pig ran out in front of me. Stupid SOB bent the lower part of my perfect bumper with his fat ass. When the pumpkins hit what was left of him, he gave the whole loaded truck a jolt.
That should be a Saginaw box on there with 3 mounting points. Once you get one in the rest will be able to utilize the swivel to at least get the through bolts in. If you have a tie rod fork it'll be easy to break the hold on the drag link. Spray the upper end of the connection joint with PB Blaster and let it soak for a few days. It should come apart like new. Those old Banks diesels were like the 2 stoke DD's and slung oil everywhere.
Yep to all of this. The drag link is new so it's been apart already. Should pop easily, and I do have a pickle fork.
I ran out of PB so it's on order with the degreaser. Cheaper to buy it by the case online than one can at a time. No big deal when it's a non-emergency.
I see so much of the "small" stuff I don't even give it a thought other than "hey look at that moron."
As far as that video and similar, I figure a horn once it's over doesn't do anything, and a horn and cursing and such during the event takes away my concentration while trying to mitigate/avoid.
Because I use so much of all of this stuff on restoration of old(er) vehicles, single can buying just doesn't cut it. Case price is the way to go.
Yep I used half a can and some old wire cleaning out the EGR tubes on the wagon.
And a can trying to salvage the OEM Stanadyne water separator on the pickup.
I get motivated at the weirdest times. Casually walked out to the pickup today and several hours and curse words later the new steering gearbox, shaft, and pitman arm are on.
It went exactly as I expected, just more difficult because of my short arms and fingers. They get into smaller places which is good but they don't have reach which is bad.
I took it for a spin. It's definitely better. The rag joint was toast and the upper ujoint wasn't much better. I don't really know for sure if the gearbox itself needed replaced but when I'm going into that kind of stuff I'd rather just get it all over with in one shot.
Once the engine cools I need to go back out and move the shaft on the gearbox a couple splines. The alignment is already pretty close to good so I don't want the shop doing anything crazy just to get the wheel straight.
Steering wheel matches up now. It tracks pretty straight, makes me wonder if needs an alignment at all. Doesn't really seem to be urgent.
I hate these cheap tires so I might put it off until I get new ones. The plan is to blast and refinish the wheels to their OEM color and standard by the time I need new rubber and that would also be the time to get everything straightened up nice.
I'd like to get this truck set up to where I could run it anywhere.
Nasty mishap on I81 in West Virginia. Flatbed lost its lumber. Some of it went through the cab.
Shut down both lanes, screwing me out of the second half of my revenue.
Oh well. It would have been a rat race type day for that money and quite honestly not worth the effort.
This way it's casual. I'd rather make a little less running easy than more running hard. My attitude would be different if the gains were exponential but they're not. You end up maximizing your gross but the extra fuel and stress makes it barely more net.
Couldn't maintain a steady 70 or 75 but anywhere between 65 and 75 with some slows to 60 per traffic conditions and I still got the same 5.5 as I usually get.
And it was windy as fack.
Half Virginia fuel though so the only explanation beyond the non-existent aero vs distance over time being a wash is maybe that fuel had less ethanol than up here.
I'm only turning about 1320rpm at 75 so it's not like it's screaming. Could be the lugging down at 62 cancels out the benefits of going slow.
Or it could be the new chassis rolling that much better.
I think I'm just gonna go slow for the bias plies to reduce the odds of a blowout and then do whatever I want on the radials.
This is why I was making wisecracks with the planner. It's a blind side off the street into that concrete cubby hole. Cars park in the shaded part of the cubby.
View attachment 86624View attachment 86625
I started to say pull in from the other direction then blind side out into the street into the wrong side of the road after for visibility and because......fuck em. THEN I remembered door swinger dock yadda yadda yadda.
If only it were big enough to turn around in there.
