Mowing my grass I noticed the front spindle tire was off the rim. I had heard you can use starting fluid if you don't have a bead blaster.
Well I didn't have a bead blaster or starting fluid. So I tried different things. WD-40 barely flames. Brake cleaner would work but I ran out because it evaporates too fast. Tried PB Blaster and PB silicone lube. Same effect as WD-40.
I knew paint wouldn't work, the only other thing I had plenty of. But a ha! I had some mass air flow sensor cleaner. It worked!
The MAF sensor cleaner kept burning and I had to air up a fireball until I got enough in it to blow it out. Some of the little nipples got cinged off in the process. Of the tire I mean. Not my boobs.
Anyway the grass is mowed and I'm probably going to get a bead blaster for next time. Or starting fluid.
Oh and I have a Goo Gone fetish now. After cleaning the Mack off I went out and cleaned the old inspection sticker residue off my trailer and took the DDI decals and farmer registration off the Ford doors. It took a combination of fire and Goo Gone kinda like hazmat stickers.
