Thought I had a coolant leak but it turned out to be some loose clamps not letting it burp properly from when the shop drained and refilled last time. After snugging everything up last night and running today, it finally built pressure, the air found it's way to the reservoir, and poofed out when I opened the cap. If it wasn't tethered it woulda went flying.
Hopefully I'm out of the woods and don't have to panic over a premature rebuild. Lol.
Crossing my fingers but it looks like it held more today than it usually would. Sitting on my slab it's always deceptive but I didn't do anything to get the temps above 190 and it stayed about centered between min and max. It's a cold blooded truck and climbing 9% grades with 44k in the box only gets it to 210. Today was mostly flat-ish interstate and not particularly heavy.
I've been popping the hood every time I think I'm on level ground and it's either stopped purging or purging less.
At least I think so. Maybe. Hopefully I'm not crazy but my sanity is starting to wear thin.
I don't like the idea of rebuilding a 9 year old day cab but I also don't like the idea of overpaying for what's on the market right now.
Hindsight being what it is and JJ Keller being the lousiest piece of shit ELD software on the planet, I should have put a new tranny in the Ford and lived happily ever after. XPO was gonna let me run paper with that old thing. They thought it was that cool.
The weird thing is if I top off while it's warm it doesn't seem to go anywhere.
At night it seeps down somewhere and will inch back up during the day, maybe. Sometimes not.
Doesn't seem very head-gaskety to me. Especially with the oil still being black and nothing coming out of the stack. The reservoir cap also always has pressure when I unscrew the cap at operating temp.
I'm wondering if it's the EGR cooler.
Usually any kind of leak you actually can't run all day and have coolant in the system. The pressure will push it right out faster than you can dump it in.
At least in my experience with cars.
I'd think my oil would be milky if it's in the pan, but maybe the orange coolant can mix with oil and not be seen?
When I get home I'm going to mix some of the orange coolant with some oil in a bowl and see how it reacts.
I mixed some orange coolant with oil and it became milky and frothy like you'd expect. And it stinks to high heaven once it gets together.
So I'm not ruling it out entirely but I don't think that's where it's going.
I’d suggest you test it for combustion gas too.
If your loosing it, not finding a trace of it, likely going out the exhaust.
The best culprit for that is EGR cooler on the MP8/D13 platform.
