Got my SCAC code Monday. Now I can do UIIA and try to get rail stuff.
Sitting in line at the John Wayne in Greencastle. Need to get this salt crud off my beautiful wheels.
Truck is clean-ish. You know how that goes. They never do a show truck job but they get the corrosive junk off.
Parked at home again. Could have run an empty into Delaware for decent money if I abandoned the truck wash but A) Delaware sucks and B) I really wanted to get the salt off this thing and not end up with a Schneider special in a couple years.
Purchased a 12v cigarette plug battery saver because the #1 killer of my batteries was forgetting to unplug my cooler.
It seems to be working, because it had sat since Sunday morning until about an hour ago and fired up just fine. We didn't get into the sub zero temps but we did get low double digits.
So I'm going to call that a purchase well made.
I don't know if the switch from JJ Keller (XPO) to KeepTruckin (me) also helped or not. Could be that not all ELDs drain the same, but I can be 100% certain that the cooler was the bigger problem.
Mack parts are expensive.
$170 for a dipstick and tube. I really only needed the tube. And it's plastic, which is why it broke in the first place.
Talk about a scam.
I kept the old one because I think I'll JB Weld it and see if it holds. If it does, that's my fix instead of replacement next time.
Talk about a scam.
Get apiece of metal and make a base…
Then solder/braze a piece of brake line to it.
Getting my steers rebalanced. Got some shimmy shake that's worst around 55-60 which is usually balance.
Got some new OEM (Mack by Sachs) steer shocks too in case that's where some of it and other random instability is coming from, but I'm going to see what balancing does first.
Tie rods, drag links, etc are in stock at the dealer too. Not sure how deep I'll have to go with this but I'm intolerant of poor handling.
I know new tire squirm is a real thing, especially with an inch of tread, but this is different.
Got a load in the morning. One way trip to an Amazon around the corner from Seagirt in Baltimore. Bobtail home from there. Been to Seagirt a bunch of times for Schneider.
Wanted to test the truck out and get a quickie in before the storm hits.
So the truck handled relatively well after having the steer tires balanced. But I was also heavier than normal (for Amazon) and cheated by sliding the tandems into a reasonable position.
I'm going to move the 5th wheel back up to where it was and see if that makes it handle like I think it should.
When I bought the shocks at Mack, I also tried out a seat I liked. So I'll most likely have one of those installed as well.
