Does anyone know if you can wire single filament lights to be parking lights and then turn signals?
Eg my headlight assembly turn signals are dual filament with three wires...one is an always on clearance light and the other is the turn signal plus the ground.
I want to finally install some mirrors that I bought but they're only a hot and ground. They're meant to be just clearance lights. But I'd like to have them as on=clearance and turn signal=blink and not worrying about the always on filament that doesn't exist.
Is it possible?
Feed gets hooked to ground for the turn light and then the ground gets hooked to power.
the best way to “see it”
go look at an old wiring diagram for a 70’s General Motors vehicle.
they had their corner marker and turn signals wired that way.
When you say feed do you mean the hot wire?
I'd definitely have to see the schematic on that. Sounds confusing.
I mean I think I get it but how it would work baffles me.
Has to do with dc electronics.
mid you hook two 12 v sources together, they actually go to 0 volts. They cancel themselves.
so what your doing is powering the light through the ground for the turn signal during the day and grounding it to the turn signal.
At night, you power it through the marker light and because the grounds are wired to the turn, it will flash alternating at night with the turn signal.
something like that.
I haven’t looked at those circuits since 1988 in depth. So going more off memory.
So the new dashcam showed up today. After a royal PITA hassle setting it up...it doesn't have an onboard display or controls so it's all through wifi and your smart phone...I finally got to buzz around with it both day and night to see how the video quality and stability compares to the old camera.
The old one was pretty high end already but the suction cup and ball mount allowed reverberations to affect the image quality. Unless it was a perfectly butter smooth ass road or I was puttering around a yard somewhere, it could get pretty shaky.
This one adhesives a plate with 3M sticky directly to your windshield, so it essentially becomes part of the truck cab. It'll rock with the cab but it doesn't vibrate.
I had to turn the event sensitivity down to low and might even have to turn it off because the ass end bouncing around is jarring and makes the camera think the vehicle was hit. This camera is actually more geared towards consumer vehicles, not stiffly sprung commercial. With a trailer it probably wouldn't have triggered anything.
It wouldn't be a problem if it didn't separate these events into 20 second clips and move them into their own folder with their own file names, breaking continuity when you go to review everything.
There's a forward facing radar option for this camera that I might buy into. It's not a subscription, just a device you stick beside the camera on your windshield and plug in. Being in control of it myself I don't mind having it, but when a company wants to put it in and have some corporate overlords watch, homie don't play. USX had radar in the 359s we drove doing P&G dedicated but it was for our reference only, didn't interfere with driving (eg no brake activation or beeping), and nothing ever went to corporate. That I didn't mind. The dashcam radar is basically a way to automatically trigger a video save when someone gets stupid around you or you get stupid around them without requiring an actual collision.
As for video quality itself, it's excellent compared to the old one. Daylight it's just amazing really and at night it has an option to boost the lighting so that you can read signs and such. The old one was basically my headlight beams and pitch black everywhere outside of that. This one you can see the moon and clouds, road signs, and a gradual falloff of your headlights.
I'm going to also run it without boost for a little bit because the downside of that is license plates (and street lights and business signs and anything else with its own source) are overly brightened to where you sometimes can't read them. I couldn't identify a couple retards on my test drive and want to see if I could without the night boost activated.
I don't like the 1 minute clips. The 3 minutes of the old one was tough to get used to already compared to the 5 minutes of the cheap Rand McNally that I got a while back. I get why they do that but my memory cards are big enough to handle 5 minutes at a time or more, and I have the ability to cut them down. I'd rather cut them down than merge them.
Overall it seems like a good device and it'll make me very happy if it doesn't randomly stop recording for hours at a time like the other one. I've missed entire legs of my trips just because it would freeze or simply not start back up after firing up the truck and I'd be too busy to notice. Heck sometimes it would even look like it was recording...but there would be nothing on the card. Ridiculous.
This one cost 2x as much as the old one and 4x as much as the oldest one, so hopefully the price reflects the reliability.
It's a 4k dashcam at 30fps but like the old one, I set it for 2k (2560x1440) to get the pausability of 60fps. I wish these dashcams would do 4k at 60fps.
I'll post a night time drive video shortly in which there were two idiots not including myself.
So the other day I finally settled on a new laptop. Don't know when it'll arrive but it's a Gigabyte brand with a 4k Samsung AMOLED screen, i7-11800H CPU, 512GB SSD, 16GB RAM, 6GB NVIDIA GeForce RTX 3060 GPU, backlit keyboard, etc.
It's kind of a gamer oriented laptop but it's not weird looking like most. I didn't want to pay the premium for the i9 or a higher GPU. I probably wouldn't notice and the prices spike hard.
Hard drives and RAM are something easily done yourself. That's one reason the 8.5 year old laptop lasted me 8.5 years. I had put more memory and an SSD in it, probably 4 years ago. In fact it'll probably keep going for another 8-10 years since it hasn't slowed to a crawl...it's the same as it was 4 years ago. I just wanted 4k and faster video processing.
And I finally got tired of using my phone hotspot as my exclusive internet service. Today I subscribed to Xfinity again even though I hate them. It's supposed to be a 400mbps service but I'm not seeing anywhere near that. My already owned router/modem is capable of 384 so I'm gonna call it good enough. Next thing is a shielded coax to replace the cheap thing between it and the wall right now. Back when service was like 20mbps none of this mattered.
Don't know if the house itself will need upgraded coax or not. We'll see.
Moved the modem to another part of the house where I have a cable running up through the floorboard and could plug it directly into the modem. Using Ethernet I'm getting close to 300Mbps. That's not 400 but it's close to the published 384 of the modem.
The rest might be limitations of the Wifi in the router. I switched the signal from 20Ghz to 40Ghz and that seems to have helped some.
I've never dealt with these kinds of speeds before so it's kind of new to me to figure out...ie what do I need to upgrade and what wouldn't help.
So apparently after some research, my Motorola modem/wifi router is too outdated to pump the modern wifi speeds. I have a new one coming that should be more than fast enough.
This one technically is fast, but it's nowhere near what I'm paying for from Comcast/Xfinity. So basically unless I want to be wired to everything I'm not getting my money's worth out of the plan.
I'd rather spend a few dollars to upgrade my hardware than basically overpay for internet. And I don't want to downgrade my plan. The speed differential is vast but the price is not.
You'll never get wireless speeds to match wired. Too many obstacles in the way of the signal. Even if you are right next to the router. The loss starts at the antenna on the router and drops from there.
Run wired to your laptop and leave the rest of the house wireless if the center point is not too far away from the router. Every wall, floor, ceiling, is a transmission killer.
Yes I know it'll never match wired but it can get closer to what I'm paying for.
I can't run wired to my laptop except to test it.
Looks like you need to move your 'office' closer to the incoming box.
I don't hang out in one spot with my laptop all the time. Sometimes I'll be in the "office" sometimes at the dining room table, sometimes the kitchen table, sometimes on the sofa.
Besides, faster wifi benefits more than just the laptop.
The really stupid part is the cable in my actual office (really just a bedroom) is dead. I already tried it.
Besides, it puts the wifi too far from the TV to be effective. As of right now it's line of sight.
I have 200mbps wired from Spectrum/Charter. Through the router I get 75mbps. It does what I need it to do. I don't game, so blazing fast isn't needed. The router easily puts the signal out for the 12 devices that run off of it.
I tried to split the incoming cable to run 2 modems. It worked for a little while. Spectrum caught it and said I needed two accounts if that's what I wanted. They got it because I wasn't using their modem and it flagged me. Oh well.
