yeah.......and......??
they required very few tools, heck, a screw driver and a pair of pliers and some baling wire, was all anyone ever really needed back then.
Good ole Henry knew what was needed, and over abundance, wasn't one of them......
that's why he said "you can have any color you want, as long as it's black"
he knew having more than one color was way too much.!!!
And yet you still needed training...
The trigger handle also turns so you can get the button where you need it. Of course I forgot that and struggled a little. But still.
It has enough beans to remove those studs that have never been off in 17 years like they're new.
I don't have my 120 setup yet but the little 21 gallon runs 135psi out of the switch, through 3/8" fittings and a 1/2" ID hose.
I don't have a ton of runtime but the first 5-6 seconds hit pretty hard, then it trickles off until the compressor kicks on around 100.
You using 3/8" makes a world of difference in power. I still have the 1/4" feed and hose on my Sears 26 gl tank and it breaks free the lug nuts on my pick-up.
Oil is the key to a properly working air impact.
Yep since I can't let it just sit there on a fastener forever, I gave it as much air as possible right out the gate. Hammer hard, knock it loose quick, and the rest of the tank is just spinning it off.
I have the same 1/2" ID hose and bumped up to 1/2" fittings for the 1" guns.
You werent stealin yer dad’s tools and takin shit apart like every other growin boy? :headscratch2:
my dad actually had carpenters tools, that i may have "mangled" a time or two, and put them in different places, where he thought he'd lost them.
to this day, i have had contractors over here, roofing, electrical, plumbing, and i'm finding shit, i forgot i hid......
When I have to use an air tool far away from the compressor, I use my old compressor's tank to store air right where I need it.
I run a few hundred feet of hose out to where I need it, but connect it to the old compressor's tank, and then I run a shorter hose to the tool.
Assuming I'm using the tool intermittently, the tank refills from the long hose when I'm not using the tool. But when I'm using it, I've got a tank full of air right there.
Without the surge tank, I'd have full pressure, but I'd get immediate pressure drop because it can't flow through a long hose quickly enough.
I use my LTL for that. 👍
Good thing the old LTL came with some spare gladhands in the toolbox, and I transferred them over to the Mack. This was on my loaded chassis at a customer yesterday.
