Sounds like 81’s just as bad in PA as in VA
Nothing is as bad as 65 from Gary to Indianapolis.
Wrecks , wrecks , and more wrecks .
Plus a "perpetual" constant state of never ending Construction on 65
Almost every other day seems to be a bad enough one to actually shut it down.
I-55 and I-80 in Will County Illinois are very close seconds especially for Fatal Truck Wrecks although that more a Capacity Issue only 4 Lanes but the population and traffic have more than DOUBLED in the last 30 years @Duck will back me on that one.
I forgot Massive Wharehouse and Distribution development along the 55 and 80 corridors have also brought a Tremendous about of Truck Traffic to that area
The fatality was in WV but generally I have better success when I run VA than when I run PA.
I thought this wreck would have been at the construction around the 12 because it's bumpy and narrow but it was actually at the 19. I don't know of anything in particular that would cause a wreck there, at least road wise.
Just wait until those iron bridges that carry I-80 over the Des Plaines River in Joliet either collapse or fall apart enough they are forced to shut it down.
If you think traffic in the south Chicago area is bad now, wait until one of the busiest freight corridors in the country has to be detoured up I-55 and back down I-355 for a year or two.
Considering that 55 is already a cluster****.
I'm laughing just thinking about how the residents of Elwood, IL will go full psycho when the local truck traffic they've been whining about for years gets multiplied by about 50.
This one has a pic
This is the truck rest area, BTW. Apparently the idiot cars were driving too fast in the rain and skipped over the grass to nail the truck. First one then another then a third with humans standing there trying to help.
It looks to me like it's this wide spot.
Just got back from pulling one of the two loads that I can do anytime between today and Monday. The other one wasn't ready, and it was supposed to be ready today by 3. I asked if they were still loading tomorrow. "I dunno." What about Monday? "Probably. We hope so." 🙄
Oh and the free ride is over. Got my first check engine light that won't go away on its own. 😏
But the 5th wheel rebuild and front bushing work was worth it. No more slack, easier clicks, less shaking, and leveled out.
In fact she rides damn nice now.
My 2016 uses an OBD2 connection for hooking up to it.
similar to what’s in cars
So if you can, then get an OBDII reader and you can clear codes etc and read codes.
I don't know why I didn't think of that when I already had a reader and Torque app on my phone. Apparently it's the P2047 for the doser valve circuit. I can clear it but it comes back immediately so the light actually doesn't go out.
That's probably why I'm not really experiencing drivability issues. It probably just can't squirt def.
My def filler cap is cracked I just noticed. I'll get a new one and see if it isn't just something retarded like that.
MP8 is the same as the Volvo D13.
You should grab your windex and let the engine build boost naturally at idle.
you’d likely have a boost leak at the elbow off the turbo. Also test your charge air cooler.
the def injector is at the bottom of the DOC/DPF. It’s got a $22 gasket to it.
you pull the injector out, you can put a bore scope into the port and see if your flex pipe is filled with crystallized def.
If your flex pipe is full of crystals, you have to get new seals and then clean out the pipe.
I’ve learn having def/dpf issues are more related to issues further upstream than the emissions.
If it cant squirt DEF its a wonder it didnt derate to 5 mph or some dumb shit like that
