I was doing something to it, probably the shocks, and some random guy stopped dead in the street to talk about it and tell me it looks good.
Headed back from TA a FedEx contractor gave me a huge thumbs up as he passed.
It's an attention getter for sure.
I saw a dump truck for sale last week at somebody's farm just south of Peotone, IL. It looked just like yours except it was a dump.
Frame probably wasn't any longer than a sleeper version of yours.
Scrap ain't paying much right now..
Last time I took cans and wire in the cans were like 20 cents a pound and wire was like 30 something..
Yeah it's pretty low. Went up a tiny bit for steel recently but not much.
Back when I scrapped several cars in like the 2000s it was $8/100. I got more for scrapping one car than I paid when it was running...and I even took the tranny out and sold that to a guy building a rod.
$1210.40 OTD for two new Michelin XZE2 steers.
Didn't think that was too bad actually. Helped the ride some but not as much as I was hoping. Still good to have fresh matching rubber though.
I'm not gonna chase the ride too much for now in case it's just begging for a load. Steers were on the list and now they're checked off so I'm just happy to have that done. If it beats me up with a trailer on then I'll figure out what's going on.
Not sure but other than the shaking that I suspect is a worn steer and/or balance issue it at least bobtails fine.
I imagine like any other tractor it rides better with something pushing down on the 5th wheel.
Could also be driveshaft imbalance. Hard to tell at this point.
I'm so far under my planned budget I can spend some money to get it figured out.
If you think it might be in the driveshaft, pull it out of gear into neutral as you are going down the road. If the shake gets worse It's your driveshaft.
Could be something as simple as U-joints.
I'll have to give it a try. But at this point I think it does just need the weight of a trailer to plant it. It's more of a bounce than a vibrate.
The cab doesn't have air ride either so that's not helping. It could just be that I'm getting more road feel because of that. There's a place across the road from STTC that can fab that kind of stuff. Might have them do that once I'm making money.
I’m sure it will need some suspension work, followed by an alignment. Definitely get that done before you run those Michelin’s too far.
Was the vibration from the steering wheel or the seat?
I thought the front end was hopping on me and maybe it was but it seems to be in the rear now. So maybe a combo of things that need addressed. Or just our roads making bobtail miserable with a tractor without an air ride cab.
Alignment seems fine, runs true and straight, and doesn't want to come out of the ruts on the interstate unless you make it.
I'll watch the tires close like I always do but it might just need a load.
