I’ll second @Oxbow here.
When I bought mine it was seized up, the air line was leaking to the cylinder too.
Soaked it all with PB blaster and got it freed up.
My mechanic learned me a trick of using a prybar to move the fifth wheel when not hooked to a trailer, using the teeth as a pivot.
Ive had to slide it in the past to get under escort required length with the stretch trailer.
Not telling you what to do, just ‘if it was me’.
You just had to one up my BFH method...
I've learned not to try and help, but were it me I would have that Holland slider working before I hooked to another trailer. I own two of them on old trucks and if you use them regularly it doesn't take much to keep them working easily. With the ability to dump the air in your suspension it's a breeze.
If there's no potentially bad consequences I'll mess with it.
I just fear getting myself into a bigger mess.
Does the cylinder leak much air when you release it? It can leak a bit and still work.
Like Blair mentioned, if you PB it up good and take a bar and wiggle the whole plate around including up and down a bit you stand a good chance of getting the pawls to free up. Worse case scenario you're out some time and PB Blaster, but you won't hurt anything.
It doesn't leak anything that I can hear but I haven't sprayed it with soap and water to look for bubbles.
i went to my home/auto insurance agent's office. he had a coffee mug filled with pens. i asked if i could "take some", he said, "take all you want"
i'll be damned if i can find one fucking pen when i need it.
I put what's her faces pen from the Lowe's DC in my pocket today. I'm gonna see if I remember to give it back. I've had it for several weeks now.
