Hiccup!Like an airplane tearing itself apart in mid-air.
cheers.Hiccup!
That's all.
Here's to hoping the rest of your rig is free of metal fatigue that will just tear apart going down the highway.
cheers.
I wasn't implying anything, but with the wording on the switch if there were no indicator light I though it might be a possibility.Oh and yes there's a warning light as big and red as you please staring you in the face when it's locked in. You can't not see it.
The lever is all the way on the left and takes deliberate action to engage.
So it would be difficult to run accidentally engaged and not realize it.
If it was a Swift fleet truck...okay yeah then.![]()
Nah you're good. Just covering all the bases.I wasn't implying anything, but with the wording on the switch if there were no indicator light I though it might be a possibility.
Could be right and we all missed it.Driveshaft looks like an old break on most of it. Wasnt holding on by much when it finally went.
Not being a Dickhead, but have you shot that rig full of grease? Those things look awful dry to me.Just dropped the shaft off to be rebuilt.
Here's pics of it.
View attachment 77771View attachment 77772
Also - not to be an egg, but I leave those center caps off so I can check hub oil. I replace the hub oil caps as soon as they become opaque so I can check them at a glance.Now I'm really in too deep. Rears are in a different package to be delivered later. They're going to be the same conical style.
Not being a dickhead...yes.Not being a Dickhead, but have you shot that rig full of grease? Those things look awful dry to me.
You're entitled to it. I like the covers.Also - not to be an egg, but I leave those center caps off so I can check hub oil. I replace the hub oil caps as soon as they become opaque so I can check them at a glance.
I trashed the ones on my trailer rather than have to remove to check.
Dressing up drives I’m all good with. Just my opinion.
I guess the same thing is achieved by shining a light under there to check for leaking wheel seals.You're entitled to it. I like the covers.
Yeah it's not fair for me to really consider my fuel consumption good or bad so early on and in sub freezing conditions.Winter is always a bit harsh. I like to go by the annual figures.
Here’s my fuel to gross last year.
What rpm are you running it at. Those old motors like higher revs not 13 or 1400 like a new truck.Yeah it's not fair for me to really consider my fuel consumption good or bad so early on and in sub freezing conditions.
I can and probably will improve things eventually with taller rears and a 13 speed though. It'll let me cruise the same speeds at more normal RPMs. And I'll be able to split these dumb small hills that make me wait until I'm slow AF to downshift. 8th gear is stupid long.
Rather than spending on transmission and rear end changes (I did both), you can simply raise the income to offset the fuel cost.Yeah it's not fair for me to really consider my fuel consumption good or bad so early on and in sub freezing conditions.
What he said . Huge hurdle for me coming out of factory new equipment to N14 and 12.7 was higher RPM.What rpm are you running it at. Those old motors like higher revs not 13 or 1400 like a new truck.
