I waited about 2 and a half hours at customers yesterday and I'll call it not at all today. There was a few minutes of gate time twice today but it didn't add anything significant to count.
I did have to wait for a mud flap on two different chassis today.
Today was longer because I had issues with brakes not releasing first thing and I was too stubborn to cut bait sooner and move on, and then once I was done with my 4 rounds I bumped into Kevin and we shot the shit for over an hour. Then I ran the add-on load to the drop lot about 9 miles. He gave me $50 for that one.
I have very little waiting so far. The biggest time sink is speed. This old truck is really slow getting going and then you're at the customer already.
It's actually not that bad. What ticks me off is chassis issues more than anything. I could have fixed the one mud flap myself and at Schneider I would have because you're basically solo at night, unless you want to hit up a TA or something. But it's faster just to dig some holes in the rubber and run zip ties through.
How does rail chassis work? Are they company chassis or is there a chassis pool owned by the rail yard?
Schneider owns theirs. JB Hunt also. But the rail yard can fix them when their shop is open. That's another benefit to running daylight. They also have roaming road service that comes in and fixes stuff if it's written up and if someone flags them down.
The "independent" side of it is mostly that old junk you pray works out, owned by the rail or some lease company or whoever as a pool. Some of it is the same kind of chassis JB Hunt and Schneider bought and those are built cheaper but newer. The old old stuff is actually usually decent but ugly. It was built damned good in the first place, it's just old now.
Containers are a mix of different owners. I had a couple UMAX, a CSX, and I think a Pacer Stacktrain which is XPO now.
I was thinking the sea ports were getting rid of their pools. I didn’t know I’d rail was following suit.
When I worked for the rail they put me at the scale/ingate. My job was to inspect containers and chassis. I was there for about 2 weeks and I think I must have put an easy 80-85% of their chassis OOS. Air leaks, mudflaps, yes, even flat tires.
The OOS yard was full. More chassis in there than ones in the good to go yard.
Pissing off Bramptonites.
Vhy put out of service?
Are you fucking blind and deaf? :dunno:
They took me off the scale/ingate and put me back on the track. :rolllaugh:
They have a guy whose full time job is to grab chassis and fix them. He's never finished and has his own spotter truck...which actually broke down in the middle of the lane once. Lol.
Usually the issues you run into were caused by the spotter.
Chassis get the shit beat out of them.
Unlike a dryvan chassis get the whole 40,000 lbs dropped on them all at once.
Then there is the top lift operators that would rather break the pin than give you chance to get out and turn it a bit more or they are shitty operators and can't lift a can straight.
I have had operators bust my pin and drop the chassis 4-5 ft in the air.
It is even worse when the spotter drops the can and chassis and is not around when the toplift grabs a hold of it.
Drivers don't give a shit because they get paid by the load and time is money and they tear up a lot of shit too.
I watched a crane operator in Baltimore slide the container on the chassis nose down first into the front buffer hard enough to lift the rear axles a couple feet off the ground.
This is why we can't crank the landing gear.
But I don't want to live just to work and acquire consumer goods either. I need to start having energy for life outside of work.
Do it man!
I know I blew through a good 20 years of my life that I can barely remember OTR and long hours.
Don't be like that.
Life is short. Money isn't everything, you can't take it with you when you go.
Work/life balance IMO is the most important thing in this world.
Do it man!
Don't be like that.
Absolutely man. I like to work but burnout sucks and takes you down for a while, rendering it all moot.
Not a single one of my "new" vehicles made me happy the way I thought it would and that's where most of the money I pissed away went.
No he wasn’t
Welp that what I get for listening to Old Timers in the TV Room at the yard..
Supposedly JB HUNT got those 53 foot rail containers..
International actual shipping works off 40 footers or 20 foot cubes or International Units a "TEU"..
JB Hunt learned it was cheaper to put 53 Footers on Train Cars than hire a Driver
Schneider and Swift also learned that in Very Short Order..
As Far as 53 "Containers" only Domestic Rail
Prime and UPS and some others put reinforced dry vans on flat rail cars too.
If you gotta go really far and time don't matter, that's the way to run it. Saves you a ton of money.
ELD making people run legit probably boosts rail even higher since they can't get as far as fast as they used to.
