389 Hood
The main sensor that regulates the temperature, injection rate and a host of other things went bad on me Tuesday morning. The DEF gauge dropped to 0, the low fluid indicator came on, the check engine light came on and it threw a couple of codes. Then it gave me 4 hours of drive time until it went it ' 40% derate' mode. After the 4 hour derate timer expires, it goes into limp mode which is 5 MPH.
I was able to get it back to the yard with no operability issues. It would intermittently operate, but the codes were still set. I called the closest dealers to me. They are telling me it could be up to 12 weeks for a replacement unit. They are allowed only one unit per day, per dealer and they have a backlog sitting in the shop waiting. I called up a buddy who recommended his mobile fleet service. He came out, hooked up his laptop and told me what it would be before he even looked. He was right.
He has a direct connection with the manufacturer and said he could get it by the end of the week. I told him to overnight it if he could get his hands on one. This same sensor is used in just about all heavy equipment with a few differences, but for off road equipment it was available.
I inquired about 'turning off', the DEF system, just to be able to use the truck until the part came in, but in order to do that, you have to delete the program from the ECM, remove the DPF and bore holes into another part to alleviate the back pressure in the exhaust. Then when the repair is made, you have to reinstall the operating program back into the ECM and replace the DPF. That software is $2500.
Looks like that 'Honey-Do' list is going to shrink this week.
