In that instance it was a result of a road hazard on the inside tire. I had cranked it up to 110 psi just to get me back to Minnesota from Ohio. Even then I had to Refill the tire every two hours when I stoppedMismatched pressure across a dual isn't necessarily a representive pic of different pressures vs footprint
How low are you gonna try?The pressure recommendation is interesting. I’ve always ran my drives at 110-115 for fuel economy gains. Makes for a rougher ride, but wear has been good.
I’m getting the same tires on the new truck, may try running them at lower pressure.
There used to be another outfit that made something similar to Halo. Units were about half the size. Don't remember the name.I’ve talked to a company up around St Cloud that uses the Halo. It’s expensive. Like $10,000 each truck.
they tend to also care spare parts to rebuild 4-6 trucks completely at any time. They get tore up.
I used a similar system on the old army trucks for CTIS.
the biggest reason they use it is it lets them air down their gravel and ready mix trucks and has helped save them wrecker bills for getting trucks towed out of work sites.
but shit gets broken. Why they keep a large inventory of spare parts. They’re a Minnesota company and the manufacturer is canookistan.
So is anybody pulled the trigger on a TPMS? Barring any last-minute phone calls, I'm supposed to pick up my new truck Tuesday, so I've been pondering what I want to do.
I've run Crossfires in the past, and may go that route on the trailer, in combination w/ a TPMS. Maybe go with the Halo, but I've got to dig some, not sure if that system equalizes duals.
There's no sense running Crossfire on the drives, my duty cycle is high enough it keeps them worn nice and evenly.
