terrylamar
Blazing Saddles is a classic.
Terry, are your "eco-tires" or whatever they're called, made out of a harder rubber compound than regular tires?
I know there's a difference in the hardness of the rubber between the ones on my passenger car, and the ones on my RV. The RV tires, which aren't designed for passenger comfort, are designed for less rolling resistance, and they use a harder rubber compound.
If your eco-tires are a harder rubber at 26/32 than the rubber used in the 32/32 tires, and if the extra hardness is enough, it COULD last as long as a regular tire.
I have no idea if they're a harder rubber though, and if they are harder, by how much. So I could be talking completely out of my ass as far as them lasting as long as regular tires. But it's possible, unless there's a limit to how hard they can make the rubber, and on regular tires, they're already as hard as they can be.
(Geez, .. with all that talk about rubber and hardness, ... I can already see the quoted post with "FIXED" under it.)
I don't know all the reasons it works. Part of it is changing to a low profile tire. Less rubber, less flex, same with the depth of tread. I am using Michelin's XDA Energy 22.5LP. It would take a long time to compare it to every possible tire out there. I use a personal example, moving from the Bridgestone 726 EL to the Michelin. Depending on what tire you start with, you could get more or even less savings. The X1 XDA Energy is an even better tire if you want to use a Super Single.
See, this is why I have no problems with Tim. He jokes, but isn't insulting. He can hold a conversation and even be helpful. I have tried to look it up on the Internet, but haven't been able to find any information.
MXS02607
his emission data is Caterpillar's best estimate for this rating. If actual emissions are required then an emission test needs to be run on your engine. | |
Serial Number (Machine) | |
Serial Number (Engine) | MXS02607 |
Sales Model | C15 |
Build Date | 2004-09-20 |
Interlock Code Progression | No Interlock Code Progression |
As Shipped Data | |
Engine Arrangement Number | 2615478 |
Certification Arrangement | |
Test Spec Number | 0K5936 |
Certification | OH_EPA/CARB H-HD Engine not for urban bus |
Certification | Aftertreatment Required |
Labeled Model Year | |
Family Code | |
Flash File | 2588360 |
Flash File Progression | 3298537 |
CORR FL Power at RPM | 450 HP (335.5 KW ) at 1800 rpms |
Advertised Power | 435hp 2,100RPM |
I've "punched" a few tires with my tire durometer and they all are within 8 points of one another, some recaps punched higher.Terry, are your "eco-tires" or whatever they're called, made out of a harder rubber compound than regular tires?
his emission data is Caterpillar's best estimate for this rating. If actual emissions are required then an emission test needs to be run on your engine. Serial Number (Machine) Serial Number (Engine) MXS02607 Sales Model C15 Build Date 2004-09-20 Interlock Code Progression No Interlock Code Progression As Shipped Data Engine Arrangement Number 2615478 Certification Arrangement Certification Arrangement Test Spec Number 0K5936 Certification OH_EPA/CARB H-HD Engine not for urban bus Certification Aftertreatment Required Labeled Model Year Family Code Flash File 2588360 Flash File Progression 3298537 CORR FL Power at RPM 450 HP (335.5 KW ) at 1800 rpms Advertised Power 435hp 2,100RPM
It is a 435Hp/1650 Peak Torque rating
It's a running gag in the movie....The whole damned movie is hilarious!
Since we're talking tires, does anyone know what the average weight difference is between steel, and aluminum?
If I went with super singles, and got that tire, what would be the average fuel savings, comparing it to the 145 rolling resistance General D660 tires I have now? Does that super single have a winter type tread?
I best not post the scene I like best.........today's nilly willy's would say its racist when in fact its just the opposite.
See Terry, ask and you shall receive, its a 435 not a 625.
Thanks Mr. Haney for the timely response!
I was about to do the same. Mel Brooks pushed the limits of political correctness with that movie in a time when political correctness didn't exists.
Alcoa aluminum wheels will save about 40% to 50% over steel. Be sure to use them on the inside on the dual setup.
A full set of supersingles are supposed to save about 1mpg over a full set of dual drive tires.
Additionally there is about 200lbs per axle weight savings over an axle equipped with aluminum wheels in a dual setup.
But.
If you get a flat with duals, you still have another tire to carry the axle end so you can limp it to the next off ramp, rather than be forced to sit on the shoulder of a busy highway.
Can't do that when a supersingle goes flat. You will ruin an expensive rim.
Additionally, you need to find out what axle you have. Some axles will flex under the offset of the rims for Super Singles. This will cause the cupping you see on the inside edge of of so many Super Singles. If you have the weaker axle you can get a zero offset rim, they can be found, but aren't as common.
That being said, do you know what kind of poundage we're talking about? With 24.5" rims? I have the old Budd style, "2 hole" steel rim. I'm debating on whether to stick with duals, or go with super singles. But, since my truck is a 'lead sled', I'm trying to shave weight, and gain mpg's. I found some aluminum 24.5" rims on Ebay for $200 ea., that are for 'budd' rims. So, I'm trying to figure out if spending $1600 on 8 rims is worth the weight savings over what I have now. If I went that route, then I would obviously get the least rolling resistance tire out there, to put on those new rims.
When they list the rolling resistance on a tire meant for duals, is that number for the individual tire, or for the duals? I'm talking about Michelin's rolling resistance comparison on their website. It shows the tires I have now, General D660's, as having a 145, whereas the Continental HDL eco having a 111. It shows my steers as having a 105, so I'm imagining that the numbers are for individual tires? So, am I correct in assuming that you would take 145, and double it, for a dual setup? That's where I'm getting confused on all of this. If I'm correct, then I could see where the super singles could save 1 mpg! On the other hand, I am afraid of getting a flat, then I'm screwed on the road!
John
This probably doesn't mean anything, but when I put the truck on 'ramps' to grease it, if I put the outside dual on the ramp, then once I had an axle seal leak start. I was told by someone that the next time I do that, to put the ramp on the inside dual, to relive the pressure.
John
