Micabay
Land Dweller
WA state just made those legal. I still haven't figured out how they work.
Can they come up with a better name than Autosock?
white sock, black sock, argyle sock, hand sock......
it's all in the way you "look" at the sock at hand.....
None taken, @Les2.
I have the same mindset as @colohayhauler's dad. If it ain't needed, leave it alone.
When my PDL and Off Road switches are not engaged and I've done something stupid like park in my icy driveway with road-warm and salty tires then try to move two days later, it's my front axle that does all the spinning. It tries the passenger side first every time. When I lock my PDL, both sides of the front axle spin together like a posi-trac axle. When I engage the Off Road switch, both axles spin both sides at the same time. Then I get off my lazy ass and throw a chain on the ice in front of my passenger side front wheel group, kick it under the outside tire and haul myself out of the ruts my warm, salty tires melted into the ice.
I don't know what those switches will or won't do at higher speeds because I figure if I'm moving, I don't need to engage them.
@Micabay....----------........where's @Tazz's birdie smiley? :neener:
Gives new meaning to the term "slippery when wet".
Isn't "same as yours", slippery when wet", the standard reply when one of the opposite sex asks a trucker his ("his" used generically of course) astrological sign?
I am amazed at how many "drivers" operate their equipment without taking the time to understand how it operates.
they "could have been" clowning around and trying to get someone into an argument..???I have heard a couple guys on the CB asking the other what that switch that said engine brake means... Or what it does..
Lol I thought the same till the other guy started explaining how it works and when to use it.
Maybe he happened to come across Justin Barnes, .. AKA: CRST Nightmare and about a million other troll accounts of his that we've banned or deleted.
The power divider is nothing more than a differential with a driver-controlled lock. Once you lock it, it is no longer a differential.
Thats pretty inaccurate...You're thinking of a diff lock that essentially make a non posi rear end into a posi rear end.
A power divider on the other hand, engages the second rear end so that BOTH rear ends are used to transmit power as opposed to im stead of just one as it is under normal operating situations.
