None taken, @
Les2.
I have the same mindset as @
colohayhauler's dad. If it ain't needed, leave it alone.
When my PDL and Off Road switches are not engaged and I've done something stupid like park in my icy driveway with road-warm and salty tires then try to move two days later, it's my front axle that does all the spinning. It tries the passenger side first every time. When I lock my PDL, both sides of the front axle spin together like a posi-trac axle. When I engage the Off Road switch, both axles spin both sides at the same time. Then I get off my lazy ass and throw a chain on the ice in front of my passenger side front wheel group, kick it under the outside tire and haul myself out of the ruts my warm, salty tires melted into the ice.
I don't know what those switches will or won't do at higher speeds because I figure if I'm moving, I don't need to engage them.
Micabay....----------........where's @
Tazz's birdie smiley? :neener:
So it seems your "off road switch" is a simple diff lock on the front axle, ...
I wish our trucks had that. We just have a simple power divider switch, and in extremely cold temps, they don't even engage unless the axle is already warm from the road. Thick oil or something, I don't know.
Ours have some kind of traction control, but it's just some stupid electronic crap that's supposed to prevent loss of control in snow.
It's on full-time, but we have a button labeled "TCS" to temporarily disable that system, for "off road" driving, but we have a flashing light on the dash the whole time it's disabled. What the system does, is when it detects a drive tire spinning, you hear a little "psssst" like an air compressor unloader valve, ... it's some kind of little air cylinder somewhere on the truck that cuts the throttle to stop the tire from spinning. When driving off road, if you disable that system, it allows you to "light 'em up" and spin the tires as much as you want, ... for... some reason, ... if that's what you wanta do. (I guess if you're in a bobtail and feel like doing donuts in the snow, ..
.. or maybe if you're stuck in mud and want to spin them really fast to fling the mud out from the treads.... never seen anybody do that in a truck, but it works with my ATV with knobbies, ..
I've been stuck many times at home. In fact it's the only place I've ever been stuck to the point where I needed assistance from another vehicle. Twice, my little Ford tractor did it, one time the neighbor's big-ass John Deere pulled it out, and another time I had to get "clever" with a come-along, using it to pull between the front corner of the trailer, and the rear edge of the tractor frame to forcibly un-couple the trailer to push the bobtail forward, out of the little holes the tires were in. Then I re-hooked at a 45 degree angle so the tires wouldn't be in the same spots.
Every time it's been stuck, one hub spins, then when you hit the PDL, two hubs spin. Sometimes it's both on one side, sometimes it's diagonal opposites, but never both on the same axle, ... unless the truck is moving.
