Life in Sector 7 G.
That same idea was poised in U.S. airspace too. NASA and SpaceX also use the AN 124 for transporting heavy items such as rocket engine stages and satellites. Although still branded Volga-Depnar, the DBA was changed to something like worldwide air cargo transporter to bypass those restrictions.
Those restrictions led to having to utilize the Air Force C-5 Super Galaxy and for the slightly smaller loads, the C-17. The then DoD said they could no longer contract US Military jets, so the Russians changed the name of their carrier to be accepted worldwide.
But $1065.60 are some pretty nice ramp fees. I wonder if Toronto will waive the fees if they fuel up before that aircraft is allowed to depart.
And that AN 225 is a spectacular aircraft. I got to see it once at NASA before all of this pissing match started. It uses every bit of that 3.5 mile landing strip to get off of the ground.
I saw one of them at Oshkosh when I was a kid. I was told it was the largest aircraft in the world, so I assume it was the 225.
Russia was still the USSR at the time. I remember being confused as to how it was allowed to fly into the US for an air show.
Not far from us is Gander. If you remember much about 9/11 it's where they landed a lot of transatlantic flights that were in the air when the attacks went down. The airport is really small maybe a handful of gates a couple of restaurants and the only movie theatre for a couple hours drive in either direction. Seeing the size of it and of the town it's amazing that they managed what they did.
The thing that's always struck me as odd is there are lots of signs and things around calling Gander "Crossroads of the World" but there are only 2-3 airlines maybe 6-8 flights in the run of a day.
Gander is mostly a stopover for fuel before crossing the Atlantic.
I worked at the airport in the 90's they used to bring in a Russian passenger plane the name was Aeroflot a Russian airline. Then the next year (they only came in the summer) it came it was Air Ukraine, Same plane. I guess this was when USSR was broken apart and Ukraine became independent.
I would be terrified to fly this plane. The tires were rounded like balloons as opposed to the tires we have with sidewalls. I remember my lead-hand (crew boss) taking me onboard and showing me this room with a clear floor. He kind of half-jokingly said it was for spying and taking pictures.
But the flight attendants though, drop dead gorgeous! Each and every one of them.
Keep in mind back then we were fed propaganda that Russian women were all fat and hideous. We were lied to. :D
Kind of like the buy fuel at the T/A or Flying/Pilot truck stop and parking is free? 🤣
I thought that ramp fees were kind of low also. This is Canada and the fees are not will kill them; it will be the taxes on the fees and the taxes on the taxes.🤣
Fun fact. Toronto currently has a terminal 1 and a terminal 3.
There is no Terminal 2 and no plans to build one in the near future. 🤣
Well, it IS in a country that only has one road. šŸ˜„
For people who are rich enough to afford a King Air but too poor to afford a Lear jet with long range wingtip tanks. šŸ˜„
Don't pick on the BeechCraft King Air. Those are the workhorse F-150's of the aviation world. They are practically bullet proof.
They're twin engine turboprops. Not cheap.
Even a single (piston) engine Cessna 172 is insanely expensive.
But I doubt a King Air has the range to cross the Atlantic nonstop from the US to any European country other than Greenland and/or Iceland.
On the north end we would fuel a Beechcraft Beech 1900 I think it was. We would have to fuel one wing half full and then go to the other side and fill it and then back to the half full side and fill it up. Otherwise, it would tip. You could see it was leaning pretty good with just the one half full wing.
Was it built that way or did someone put in long range tanks? šŸ¤”
I'd be nervous flying in cold weather in a small plane with tanks in the wings.
I'd damn sure be sampling the fuel before takeoff.
I don't know if all planes have this, but several of the small single engine prop planes I flew (or flew in) had little ports on the bottoms of the wings where you can take a clear test tube thingy and draw a sample of the fuel from the bottom-most points of the fuel tanks, to look for water or other debris.
Balance is of critical importance to a plane in flight.
For some reason a lot of small planes do not have the ability to draw fuel from both tanks simultaneously, and the pilot has to periodically switch between the two tanks in order to keep the plane balanced on the aileron axis.
That would annoy the shit out of me unless I had an autopilot. I'd never be able to maintain a perfect heading.
But ice in the fuel lines could render one tank unusable, requiring an unscheduled landing somewhere before the imbalance gets unmanageable.
I had something like that happen in a Volvo truck, although those tanks were plumbed differently. Ice made one tank empty out while the other one remained full.
The weight imbalance doesn't matter a damn bit to a truck on the ground, but it would in a plane in flight.
I think that's how John Denver was killed.
It was built that way. It's a high wing aircraft. (if that is the right term). It was also overwing fueling. Kind of like how you fuel your car with a hose and a nozzle, but you need a ladder.
Do you mean tip tanks or regular wing tanks? Tip tanks are pretty much for takeoff.
A sample is taken every day from the fuel truck. Check for clarity and water contamination.
They add a product called Prist to prevent freezing. A pilot may even request this in the summer with high humidity on the ground.
Prist is added to all Jet-A at the rate of 1.2 gallons per 1000 gallons of fuel.
Both the storage tanks and the trucks are sumped every day to remove any moisture built up in the fuel system filters and main tank. Even the 1,000,000 gallon storage tanks at the fuel storage facility are tested every day with an API test kit and any water is drawn off of the bottom of the tanks.
Today we took my mom and her twin sister out for dinner for dinner for their 75th birthday. Good meal and all that.
It happened to also be a guy's birthday at the table behind us, but they had no birthday cake. We gave him a slice of the cake we had.
Everyone should have cake on their birthday.
Just a bit of a backstory, My Father was into the street racing scene back in the 60's ( he lost his license doing it) My Mom knows all about that scene.
As we were driving home, I pull up beside her and point forward. She slows down and opens the window. I point again and say, let's go! She mashes on the gas and takes off for a bit. She was laughing.
Happy 75th!šŸŽ‚
Earbuds...
I got three pairs now. One white and two black Samsung's. The white are for my laptop and the black, one is for work and the other for watching movies on T.V.
Yes, I know that one pair will work on all three, problem is, they all want to connect to the T.V. as soon as I walk in the door. I don't want to be scrolling through my T.V. settings to get the buds to disconnect so I can use them with my laptop.
Today I grabbed the wrong earbuds to take to work. I was surprised that I could add an additional set of identical earbuds. Samsung is smart, they just call it earbuds 2.
It's just that I am trying to save the best buds for home and use the one that don't have noise canceling feature functional for work.
I only have three sets due to upgrading but it is nice to have one set for each device so I can charge the battery one while I am using the other.
