Life in Sector 7 G.
We have a fleet problem being all O/Os of different heights. I can drop for myself and it's hitting someone else's tires. Someone drops for themself and it's above my plate.
One thing I miss about Schneider is the frame ramps and everyone having the same truck. Probably the only thing I miss really. Other than the paychecks.
Where I used to work when I was OTR that was a problem because fleet ran 22.5 and most O/Os had 24.5 tires.
Coffee and donuts for the boys today because, they deserve it and I think I am the next to last guy to take their turn at buying coffee and donuts because I am the junior guy on my shift/team.
Correct we pack them in there pretty tight because we are at times a good 200 trailers above capacity.
Fleet drivers are told and there are notices for them to drop the trailers low so they can pull them and out and crank the gear and do the opposite when putting trailers in.
This guy was a fleet driver. They are not even supposed to be bothering us with THEIR problems.
I shouldn't have even stopped.
Correct me if I'm wrong, but don't just about 95% of trucks today have air ride suspension? Stage up, lower the gear, back in the hole, blow the bags, release the pin and walk out gently. Next guy comes in to pick up, stages up, blows the bags, backs under, sets the pin and then refills the bags. By the time he has his pin physically looked at and the air lines connected, the bags are up for the pull out. Clear the side trailer and raise the gear. Wave bye-bye to RJ and he waves back cuz you didn't bother him.:thumbsup:
As we've already said that's great and how it's supposed to work if everyone has the same equipment and drops properly.
The fact that they don't is why spotter trucks have hydraulic 5th wheels.
Does this require an electric 5th wheel release?
I remember Schneider had pneumatic ones. Probably electric over pneumatic but an air cylinder under the 5th wheel plate pulled the jaws open via dashboard rocket switch. Kind of how air slides work.
It was awesome, and irritating, depending on the day.
I don't think I'd pay for the feature myself because it's like power steering if it had a high intermittent failure rate. It's nice when it works but it's harder to pull the handle against the vacuum when it doesn't.
I can pull my handle like it's nothing but when I was at pumpkin I had both feet against a tire and a puller handle yanking with everything I had.
He sees you're the yard jockey and figures you were the one who packed them in like sardines, so you should pull it out.
Yard jockeys never have to crank dolly legs with that hydraulic 5th wheel, so lots of them forget about leaving room for the driver of a highway truck to get in between them to crank them up.
Nobody wants to have to crawl under a trailer to crank dolly legs and get grease all over their clothes or in their hair.
THAT'S RIGHT....!!
those god damned blasted yardmen...!!!!!!!
Electric over pneumatic is what I meant.
I had a truck with that for a week once, a couple years ago.
I'd hit the switch on the dash, then jump out to finish unhooking and I'd still automatically reach under & pull the pin only to remember it's already out.
why that god damned yarman, he ought to be castrated.
OK we're not going to neuter @Rigjockey .
That would be extremely impolite. It's not how we treat our neighbors.
Unless they're from Quebec.
I think it only works when the brake is set, or since the truck was also an automatic it probably has to be in neutral.
There were some safeties like that but I don't remember.
I don't remember the specifics but I do remember it wouldn't just let go any time you hit the switch.
Mom's dryer broke down so she was looking for a new one. I said why don't you get a Samsung like the washer?
No, I want a whirlpool or a Maytag she says.
I said you know the Maytag repair man (Gordon Jump) is dead right? :biglaugh:
tell her to get a speed queen. maytag is crap since whirlpool bought em out. we had a samjunk fridge it started throwing off codes. we called samjunk and they had no idea what the code ment. they sent a tech out and he said there was a freon leak and the motherboard went out. i was like all at once!!! he said there crap and we repair these and LG'S garbage the most!!!
:foreheadslap: Now he tells me. I guess I'll go out and tell the wife our appliances are junk. They were all put in brand new in 2016. Washer, dryer, main fridge, 3, 40" TV's, a 55" TV and an 85" TV. They are Samsung. And the computers and printers are all HP and absolutely none of it has given me an ounce of trouble. :hide:
Prior to that, in my other house, I had a Maytag washer and dryer that were 20+ years old, along with the Amana fridge, stove & nuke.
Just because you don't like a product doesn't mean you have to trash it as the worst, junk, crap, whatever. If you take care of anything, you'll get your rewards from it.
How many here take their fridge or freezer and blow out the coils with compressed air, clean the defrost waste tube and check the current draw on it occasionally. Appliances, just like cars and trucks will talk to you, IF, you know how to listen.
I forget what brand my OG fridge was but it wasn't a Speed Queen (🙄😉).
It just got old and tired and died one day. IIRC the data plate put it at 20 some years old. It was white anyways so I was happy to replace it with a cheap stainless LG. 😂
I'm with you though the bashing of brands is nonsense.
