Sarcastic remark goes here
That was me yesterday.I fixed the GD dishwasher Thank you Google. I was just about ready to junk the damned thing.
Now I feel like a dumbass because I was over thinking it. I just needed to drain water from an area that is not visible. The way to do that is simply tilt it and let the water piss out on the floor. And here I had the whole front panel off and everything.
I get frustrated when things don't work the way they should and then, and then I don't know what happens to me.
All good now![]()
The rear latch on the vanmobile has always been a pain in the ass to open. And the rear heat didn't work.
So since it's currently trapped in the shop until my lazy ass fires up the snowblower, I decided I'll pull the plastic off the inside of the rear door and figure out what's wrong with the latch.
All it needed was lithium grease sprayed on everything.
Anyway so I pulled the whole rear right interior side panel off to access the rear HVAC system..
I could hear the fan running but nothing ever came out of the vents in the ceiling. So I figured a duct was loose or something.
To get the panel off I had to remove the upper seat belt strap holder thingy and both the rear center entry threshold thing and the plastic across the top of the opening too.
I get all that shit off and out of the way & then I turned the key on to turn on the rear heater fan.
It was sucking in cigarette smoke like a vacuum cleaner, but it wasn't leaking anywhere.
Then I noticed there's a vent down by the floor that I thought was a speaker because in the exact same spot on the other side there's a little 6" subwoofer behind the same kind of vent.
That's when I reached up front & hit the air conditioner button (even though the engine was off).
When I did that, the rear HVAC started blowing out the ceiling vents.
So it's only the rear air conditioner that's supposed to come out the overhead vents. The rear heat just comes out of that speaker grill.
Nothing was wrong with the rear HVAC system. I just never read the f*in manual
