According to the internet it is impossible to go over the payload or towing capacity of a Ford Ranger
Well as long as it's not the early 90's model with rusted out spring hangars, they're pretty solid little trucks.
One time when I was in "science mode" which is something my brain seems to do on it's own, I decided to compare my '89 Ranger to my' 88 F-150, structurally.
I'm not a structural engineer, but I came up with a couple of different ways to compare:
I measured the height of the frame rails from top to bottom and width, halfway between the F&R axles where the stresses are highest. Then I measured the wheelbases. Also measured the metal gauge thickness of the metal plate the frames were made of.
I did some math using a calculator app website for architectural engineers.
You input all those values and it'll give you the approximate load bearing capacity of the frame rails, (assuming it's a just a straight piece of C-channel).
You can also adjust any value and it'll update the others. For example you can type in a longer wheelbase and see how much it reduces the max load capacity when the load is applied to the center of the span. Or you can lock that load strength value and as you change the wheelbase it'll change the height or metal gauge requirement in order to meet that locked load capacity value at the new length of span.
It's a really cool web app. I probably have it bookmarked on one of my devices..
You can also do the same calculations with other materials such as various types of wood, plywood strips laid on edge, round or square tubing, etc.
Anyway it turns out that for their wheelbases & frame size, the ranger frame is capable of holding more weight in the middle, relative to it's Gross Weight (no trailer) ratings from Ford. I remembered to multiply the frame rail capacities by two.
If I lock the ratio of channel width, height and metal thickness to keep them proportionate as the overall size is changed from the Ranger's wheelbase to the F-150's, it turns out the frame ends up being taller, wider and thicker than the F-150's. So naturally their weight bearing capacity increases a lot.
So, adjusted for its smaller size, I'd say the ranger is tougher than the F-150 as far as overloading it.
I didn't compare anything but the frames though.
