I'm about 90% decided that I am going to start doing extended oil drains on my truck now that I've had a rebuild. I've had an OPS Ecopure system in the truck since day one, but have simply just been replacing an extra oil filter every 15-20k for the life of the first engine. Did that because Fitzgerald basically told me that any failures they could point toward the oil would void my warranty if I was doing extended drains. Well, I did your oil changes as advised, and your engine was an epic fail, so thanks for nothing Fitzgerald.
Anyhow, with the OPS Ecopure, I "think" that the recommendation is to replace the bypass filter every 25k, send in a sample, and go from there. The full flow stock engine oil filters get replaced every 50k. I will be calling OPS to verify those numbers with them, but I think that is how they explained it to me a few years back when I first got the truck.
I'm coming up on my 2nd oil change since the rebuild, so I will getting my first sample then, then starting the extended drains following this oil change if I go forward with it. Gotta be honest, I'm a little nervous about doing it.
