Detroit DD13 vs DD15 for 80,000 lbs: Fuel Economy, Power, and Maintenance Costs
I like the autos on grades and in traffic.
I hate the autos finessing under a trailer and into a dock.
I did drive a loaner 2016 when my truck was having front end work done it was a bitch backing under a low loaded trailer, the 2019 not so much. The new truck acted much smoother backing that slam dance into the pin didn't happen.
Auto is fine getting under a trailer if you have an air dump like all trucks should.
New autos supposedly have some progrmamming to assist with backing as well.
Not that. The throttle tip in. All or nothing. They aren't smooth to engage, at least on Schneider's super duper fuel economy above all else programming. They go to neutral at every opportunity.
One second you're sitting there in reverse but neutral. A little throttle does nothing then BAM! you're nailing the pin.
Schneider bought the cheapest version they could get away with.
Programming to assist backing? Nah!! Next thing ya know, they'll want seats that don't give them permanent spinal damage!
:mad-97:
One old School trucker used to come into the plant and he was bitching about the clutch needing to be rebuilt on his automatic. Buddy used to sit there in a pot hole and because the truck was not moving, he figured he could just let off the brake in gear and everything would be just fine. :D
The only reason they still offer the 15 is because people think they need a 15. That is what the dealer told me. The 15 is only rated for 1750@505. The 13 will go 1850@505.
Opened that can of worms up quite some time back.
Still undecided
Still undecided
I don’t know why they still carry it. Get a 13 or a 16. No need for the 15.
They push the DD13 as a regional operation engine. When I was spec'ing a truck, they pushed hard to sell me on shorter gears if I went with the 13 litre engine, even though they were rated the same. Couldn't get a straight answer as to why when both had an 400/1750 at the time.
Those who are operating the DD13 seem to be very pleased with it, though.
It’s was mentioned briefly when I ordered mine. The reason I shut it down was resale value. Who is going to buy a heavy haul unit with a 13L motor? I have no doubt that it would do it, but it’d be hell to try an unload later. I mean you are running a 12.7 liter motor, do you have any complaints? The 12.7 470 horse was a good strong engine.
12.7 works great for me. Engines went big to deal with emissions. That’s all been figured out now, so the sizes are coming back down.
Had that problem even with little trucks
Fix it again Tony went from the 5.9L cummins to the 6.7 only to make up for the performance losses they knew they get from emisson crap
