Captain504
Active Member
Can you use a truck with a 4.56 gear ratio and 15 speed 3406B CAT for daily flatbed hauling?
15 speed doesn't have a very tall Overdrive, and even running tall 24.5, that's going to be a very short geared truck. 1800 @ 63 mph.Can you use a truck with a 4.56 gear ratio and 15 speed 3406B CAT for daily flatbed hauling?
I am changing careers and just trying to get up to speed.15 speed doesn't have a very tall Overdrive, and even running tall 24.5, that's going to be a very short geared truck. 1800 @ 63 mph.
Yes, those old cats will turn 2100, but engine life is much better if they're kept below 1800. Back in the 80's, Jewett Scott pulled their Fleet back to 1750, and saw a substantial reduction in bottom and failures e nd increased TBO.
ThanksThe higher the rear gear numbers, the more low end grunt you will have. 4:56's are stump pullers. You'll get 200,000 pounds moving like it was nothing. However, you won't have a respectable top end without over-revving the engine. Plus the fuel usage will be ungodly and the wear and tear on the motor is significantly higher due to the high RPM's. 3:43's and 3:55's are a perfect combination for a direct drive transmission.
No it's just the opposite.I am changing careers and just trying to get up to speed.
Does long legged simply mean the truck will be slow with 4,56 gears.
Only if you're going to be doing some heavy haul or running local in a mountainous area with tons of steep hills.Thanks
is it a good idea to purchase a w900 with a 15 speed behind a 3406b and 4.56 gears?
You countered yourself. Read what you posted again.No it's just the opposite.
Think of it as two guys walking, taking the same number of steps per minute.
One guy is 7 feet tall and the other guy is Danny Devito.
The 7 foot tall guy is going to have longer legs and therefore a longer stride. He's going to walk faster than Danny Devito because Danny Devito is going to have shorter legs and a shorter stride.
Your truck is Danny Devito in this comparison.
So it'll be slow.
But it'll have a shit ton of power.
Not a metric shit ton either. A real one.![]()
I'd buy it if the truck was overall a good deal, and put taller rears in it.Thanks
That truck is not going to be new either. It could have all sorts of things lurking. They haven't made a blue button 15 speed in quite a while if I recall...Thanks
That's true. I was going to have a 13 double over put in the Ford for the same reason. Low HP engines like it has need gearing to help get them moving.Easier and cheaper to just swap the two top cogs and make it an OD. It takes about an hour.
EDIT: A 15 is a perfect transmission for the swap. You still have the 3 low holes to get a heavy load moving.
Yeah you have to take old trucks on an individual basis.That truck is not going to be new either. It could have all sorts of things lurking. They haven't made a blue button 15 speed in quite a while if I recall...
Pictures for this thread will help.
We are simple people and do well with pictures.
