Peterbilt 386 DEF system problem
Trucker386
Hello, I drive a 2012 peterbilt 386 and I have been experiencing lower mpg than usual and the truck asks for the regeneration to be perform at shorter time periods. When I place the truck in relay the truck feels like it is accelerated similar to when performing a regeneration. Cummins has determined that all of the DPF filters sensors are working but they cannot determine the condition of the filter or catalytic converter. Any help with this issue is appreciated.
They should run all the troubleshooting for a 3582 fault code to include a Nox Efficiency test. I am willing to believe you have a partially plugged DOC, Decomp Tube or a catalyst that isn’t performing anymore. Very very common on that era of Cummins engines regardless of size.
No#1 trust no one....learn the system yourself...30 years as a tech I can tell you there is few that know cause in effect!
If you take the time the system is quite simple... clean you own filter... use YouTube
