Ok ran a ground right from Batt to dash gages ,,,nothing??also new ground from frame to cab...one other thing the two relays inside left side dash small one that has two big wires and a plug when off only one big wire lights up when on both big wires light should one of those plug wires be lit too ?? I'm going outside and see if one does lite..........little white wire does light when key is on ,,,,still no gages...This has got he beat ,,,as far as "Bad wires"cant find a one...even checked behind the fuse box ..as far as the relays working ...left side inside dash...left one and right both have power to them and the square one that plug in I went thru all of the with a good one showing me there working.......Any other idea's?
