Sleep Apnea Test - I think I am going to do it
I have put the concern about having sleep apnea on the backburner for a few years now. At this point, the wife wears ear plugs when I am at home because my snoring has gotten so bad.
My plan was to ignore getting tested, and just lose weight. You know, via diet and exercise. Well, I think I have put this off for so long that I am just too tired at the end fo the day to even think about exercise. I've noticed for quite some time that I am just not as alert as I used to be, and obviously, I'm always tired.
I've been monitoring my sleep via an app and my apple watch. I'm lucky to show 4 hours of restful sleep, and none of it is for more than 30 minutes at a time, if I'm lucky. Something is obviously preventing me from staying in a deep sleep for any amount of time, usually no more than about 10 minutes.
I emailed the folks at NASTC this evening, and got surprised by a phone call from the person I emailed. We talked about the testing procedure that I would be doing at home. First would be an oxygen level test. Basically putting a monitor on my finger to monitor oxygen levels overnight. From there, if that test indicates any sore of concern regarding potential sleep apnea, they will recommend the sleep study, again done at home.
If it turns out I do have sleep apnea (I am almost positive that I do), I will get a machine, and then have a zoom meeting with the doctor that they use in order to explain the machine to me and guide me through setting it up.
A couple reasons I am doing this. First, because sleep apnea obviously leads to more complicated health problems. 2nd, I want to speed up the process of getting healthy again, and I think the lack of energy from not getting rest is causing a major problem there.
One key discussion we had was getting off of the machine and cleared of having sleep apnea, because I have no intention of wearing this thing my entire life. I will if I have to, but if the problem goes away as I lose weight, I don't want to continue having to wear it because of DOT. He told me that they routinely get people off of the machine as well. Sometimes, they do it via the oxygen level test with and without the machine, sometimes it is required to do another sleep study, all depending on the DOT physical location.
I would be tempted to just not tell them when I get my physical, but I think it is better to be up front about it.
I'd be really leery of having anything on any official record. But if you know you're not sleeping, you've got to take care of that.
Yeah, this is exactly what has prevented me from getting tested. At the same time, it’s the exact thing that I think will drive me to get cleared ASAP.
Last Orientation they were measuring neck sizes..
But having been home and off the road afew years I was a Lean Mean 182 at the Clinic for Physical
Weight has little or nothing to do with sleep apnea.
You don't want to work for Walmart with Sleep Apnea. They have a machine that tracks all that and if your percentages fall off they send you home until you're statistics get right again.
About the only way I'd volunteer would be on my own terms the way @Mike is doing it, with a clearly defined goal of eventually getting off of it.
Walmart is too structured they'd never hire me nor would I even apply
Same with Schneider. It's a witch hunt.
Some guys got caught in the net but to be fair they did say as much as they hate the machine they do feel a lot better.
If you get one and faithfully use it I guarantee it will help but if you can keep from having it put on your physical card I would I don’t think it would be that easy to get off your record and your card is then only good for one year.
Check into the sleep apnea clinics that specialize in mask alternatives. There are surgical solutions. They can smooth out your nasal and sinus passages. If you have ever broken your nose they can smooth and widen the nose damage.
I would be discreet about letting your employer or DOT know about it. You will be stuck with a mask and a 1 year medical card forever.
Or in prison if I ever have an accident and it is discovered that I hid this.
I am working with NASTC on this, and one of the key discussions we had is having a pathway to get rid of this as well when/if I no longer need it. To get removed from it, it's a matter of retesting at home, and having the results show that I am no longer experiencing symptoms of sleep apnea.
Yes and if you have an accident and you have a CPAP machine in the truck you and your company will be sued anyway. It is much harder to find out about your sleep apnea if you go to private doctors about it.
The surgical solutions are a permanent cure to an ailment. The lousy sleep your going to get with a mask will make you tired and more likely to get into an accident. Besides, most of the truckers I know with masks stop using them within a few months because of the hassle.
So you really have no real world experience with using a cpap or sleep apnea is what I’m hearing.
mndriver. I don't use a mask but I know several people that do. I'm sorry. Does that disqualify me from this discussion? Did I say one thing that was wrong?
Considering that your “advice” has substantial legal ramifications as well as qualification issues, .....
I’d tell people they’d be foolish to follow it based on actual first hand experience.
