I don't know oil from oleanders, but I do have a story to tell. I've probably told it before, but anyway:
This was in the early 90s, and I know oil and additives have changed a lot since then, but it gets back to the differences in oil.
I had a 1989 T600 with a B model in it. I had taken it to Cat in Boise for a recall of sorts. They wanted to cut an additional water passage in the block to provide better cooling for the #6 cylinder.
I was watching and chatting with the mechanic as he removed the valve covers, and he asked me what kind of oil I ran. At the time it seemed that most guys running Cats preferred Rotella because of reduced oil consumption, as did I, and I told the mechanic that. He said "Wow, this engine is really clean for a Rotella engine". I questioned him about what he meant and he said that Rotella engines usually leave a lot of deposits, and he showed me what he was referring to on my valve covers. I asked him which oil was the cleanest to use, and he said Delo. He also went to great effort to explain that he had no knowledge that Delo was any better than Rotella, and he wasn't putting Rotella down, but just that he could see a difference looking inside depending on the brand of oil that was used.
I have run Delo ever since, but I don't believe it is necessarily better, I just liked the idea that the inside ended up cleaner.
So, the point to all of this is, at one time many years ago there indeed was a difference between brands. Whether it was the base oil or just the additive package I don't know, but in my experience there was a difference. Plus, the engine had a unique smell to it right after a Delo oil change.
