I have a 2020 Peterbilt 389 with 18 speed transmission. When shifting from direct to overdrive the transmission shifts in hard when I let off the accelerator. Peterbilt said o rings leaking oil and replaced them. Still doing the same thing.
The Eaton Fuller RT-18 manual transmission is the iconic industry standard for heavy haul semi truck transmissions with ratio flexibility and unlimited GCW.
