Fuel What are some of the fuel economy improvements you've made to your engine?
I just came across this interesting sidebar in the July 2014 issue of Commercial Carrier Journal where a Yokohama Tire exec breaks down fuel efficiency. For every dollar spent on fuel:
- 60 percent is wasted by engine inefficiency
- 21 percent is wasted by aerodynamic drag
o 50 percent is wasted by the drive position
o 35 percent is wasted by the trailer position
o 15 percent is wasted by steer position
- 13 percent is consumed by overcoming tire rolling resistance (average of all tread types)
- 4 percent is consumed by the load
- 2 percent is consumed by the drivetrain
Based on this info, efficient engines are by far the most important keys to fuel efficiency. What are some of the fuel economy improvements you’ve made to your engine?
Copperhead
I took the stock wastegated turbo off my Series 60 and replaced it with a larger non wastegated Borg Warner turbo. I put on a ported/polished/ceramic coated exhaust manifold. I put a blanket on the turbo. I ran that back to twin stacks out the back with Walker Megaflow mufflers. Far better performance and economy than stock by a considerable amount. EGT's considerably cooler on hard pulls. ECM was tweaked to remove the fuel robbing '98 EPA settings.
Injun
Rabid Squaw
- 60 percent
- 21 percent
o 50 percent
o 35 percent
o 15 percent
- 13 percent
- 4 percent
- 2 percent
By my math, that's 200%. If I'm wasting 200% of the efficiency of each dollar spent on fuel, that means I spend an awful lot of money sitting around doing nothing. I think your Yokohama dude is FOS.
Pedis dextra elevation
derekbrian
For fuel efficiency of the vehicle one and the foremost required thing is the maintenance of the vehicle in the form of its regular service and get it checked at regular intervals by the professional mechanic. This process will certainly improve the fuel efficiency of the vehicle.
