If the outside temperature is such that the unit can't reach the set temperature it can be a number of reasons. First, did the self check mode indicate any problems?
The condenser coils can have dirt and debris in them that prevents the coolant from giving off enough heat - spray washing it may be all it needs.
Not enough coolant in the system. That usually results in an error code.
ps temp is mild, easily maintaining set 33 no prob, it's like a switch or sensor isnt allowing a auto cycle off. defrosted manually, turned off back on still no change. Wierd?
Spoke to thermoking said bring it in could be a # of things. Called my old company, they told me it's a bad battery. My amperage is to high. so guess I'll go here in iowa to tk. getting that battery out is a pain in the keister
I tried once and punted, its ridiculous
