four wheels
NoPower2Move
Anybody know reasons for car tires squeeling while going around a corner or stopping at a light or stop sign at slow speeds?
Yup, When your tires start squeeling while making a turn at low speeds it's time for new tires.Anybody know reasons for car tires squeeling while going around a corner or stopping at a light or stop sign at slow speeds?
rigjockey said:Yup, When your tires start squeeling while making a turn at low speeds it's time for new tires.
Rubber Duck said:The alignment of the front wheels is set to make them perfectly parallel to each other only when they're both facing straight forward.
The harder you cut the wheels, the further misaligned they are with each other, and since they're not pointing in precisely the same direction, one of them will slip sideways, making them squeal. This is normal.
Sometimes hot pavement or underinflated tires will cause them to squeal. There's a parking garage in Chicago at Mrs. Duck's doctor's office, where at the ends of each row, you have to make a sharp 180 degree turn on concrete that's kind of a rough surface. Everybody's tires squeal in those turns, mainly because it's a sharp enough turn that everyone's front wheels go far enough out of alignment until they straighten out again.
If your tires are squealing when moving in a straight line, but on the brakes, it could be low tires or they're out of alignment. When you're on the brakes, extra weight shifts onto the front axle, which is why the front end of the car dips down. With more weight on them while braking, if they're out of alignment (when steering straight forward) it could make them squeal just because there's more friction between the pavement & the tire that's side-slipping a little.
Injun said:Too much throttle.
Speed in and of itself does not cause tire squeal.
Also since the turning radius is different the tires are actually moving a different speeds. The outside tire has a wider arc while the inside tire has a smaller arc.
Rubber Duck said:The way the steering linkages are designed, they can't have both wheels lined up perfectly with the different sized arcs they have to follow in a turn. So the inner tire always side-slips a little bit in a turn.
On hot pavement, the side-slipping tire will squeal as a result.
Man we're some real bright folk on here the way we got to the bottom of that so quick. Maybe we should tackle world hunger next.
Rubber Duck said:You take the hunger issue, cuz I'm busy working on solving the world's energy crisis.
I think they're interrelated.
Rubber Duck said:The only thing they have in common is that the powers that be will never let those 2 problems be solved.
Also since the turning radius is different the tires are actually moving at different speeds. The outside tire has a wider arc while the inside tire has a smaller arc.
They have more in common then you'd think but I will leave you to your efforts.
Just what I thought...most likely had something to do with the alignment and how I like to drive around corners and come to stops. Low tire pressure? Wouldn't they squeel more if they're over-inflated?
If you car never did this before, and your tires look ok (not bald or low on air) and the temperatures where you're driving hasn't changed much since before it was squealing, then you oughta have the alignment checked.
