YesDid you get the Kevin Rutherford Scanguage?
DubbleD said:Exhaust Gas Pressure sensor.
I just finished reading the thread that you mentioned "scangauge" ... What is it? I get the jest of it from your statement here... How is it connected? What is the cost per unit?I have had 3 consecutive Freightliners that get some code similar to that occasionally when I start the truck. Absolutely no reason for the code, but it WILL put the engine in derate. Typically it goes away in a couple key cycles.
Another reason I am got a scangauge, so I can just clear that code immediately when it decides to come on. Doesn't happen often though. I mainly seems to happen after shutting the truck off in really cold temperatures, then restarting.
Did you read this note?Here is the one I ordered.
https://www.letstruck.com/store/scangaugekr
Yes. A few of them will occasionally reset. There is a temporary fix for it if you happen to have the problem, and as soon as linear logic has a permanent fix, they will update the scangauge for free.Did you read this note?
We do not recommend use on the following trucks2008 and newer Freightliner Cascadias or International Prostars - all engines
Well not the steering wheel holderI checked out the link.
Damn! Why hasn't this been discussed before? Scangauge provides the same info the Cat Messenger does on the 07's with the added benefit of clearing codes?? H ell yeah!
When I gave my customized 2007 387 up for the 2010 the one piece of equipment missing was the Cat Messenger. Cummins must feel drivers don't need information like... Fuel temp. I mean... what good would that do me? Let's see...at 00:01 our outside temps tonight are supposed to be -25/-35... Fuel temperature? Bah...who needs that info?
Is that the "Scangauge D" for RV and OTR trucks?
Does it show amps + & - ?I keep my scanguage on volts, oil pressure, MPG average and MPH
Whatever happened to ammeters anyway? I haven't seen one in a vehicle in a long time.
Kenworth was one to all ways have a amp gauge up til the early to mid 2000 year model trucks.Does it show amps + & - ?
