The tiny little coolant overflow take inside the unit is a problem with many units. If the coolant falls below a certain level the engine will shut down. Usually when it's 20 below zero in North Dakota. The coolant comes out from road vibration through the vent hole. After getting sick of putting 2oz of coolant in I modified mine. Rigmaster has since created a larger tank but it's still not big enough. It's just means it doesn't happen that often but it still happens.
The tank you see is a lawnmower gas tank. The bracket holding the tank on is also the bracket that held it onto the lawnmower and worked great. Just drill a hole in the side and run the rubber tube inside and connect where the small tank hose was connected. Go to Home Depot and get a rubber grommet to line the hole in the side or it can cut the hose.
