Parasitic power drain
You'd test for specific gravity of you really wanted to see if it was charged
Is that what the hydrometer is for?
I have one but don't recall ever using it.
I use my coolant hydrometer every fall though.
Once again, I tend to follow the manufactures instructions
If you truly wanted to load test, you'd do so with an adjustable carbon pile.
WTF does a load tester have to do with charging a a battery? Load testers are for determining if the battery is junk or not. Not it's state of charge.
Yeah, specific gravity will tell the charge state, load testing gives you a peek at the health of the battery.
The absolute best way to charge a battery is quite involved, with charge rates varying with different levels of charge, and the input voltage needs to vary as well. On top of that they throw some transient voltage "noise" that help break up any sulfation on the plate faces.
If y'all want ta see if yer batteries are charged, just hook yer nads across 'em. If yer still capable of procreation, it ain't charged.
:D
Really judging from the amount of pill commercials on TV I would hazard a guess there are a lot of boys gonna have a problem passing your test. They were not procreating before then, without help.
I bet if doctors were required to ask patients seeking viagra to show them a picture of their wives for statistical purposes, they'd discover the true cause of erectile disfunction quickly.
:puke:
Create account
Log in
