makintosh8
Hi for all,
In our service we doing small maintenance for Peterbilt Truck with next specs below:
Model.378
chassis WT 16729
VIN: 1KP-FDT9X-X-2D577371
MFG.Peterbbilt Motor Company
a division of PACCAR
Denton , TEXAS U.S.A.
With CAT C-10 Engine
Ser No.3CS24913
ECM Software 208-5743
Description of a problem:
On the Truck the Cruise Control system doesn't turn on.
Namely , when we turn the PTO switch in position ON , then on Dashboard panel the PTO lamp start working. But, when we put the near switch to position SET , the RPM is not increased.
I checked all wires from the switches till ECM ,switches and connectors and don't found any damages or failure.
My question it is possible to deactivate the PTO mode in ECM through CAT-ET software or not?
Also,will glad for everybody,who already had the same problems,found out the resolution for it and will kindly to advise the decision of this malfunction.
Regards,
Me.
Model.378
chassis WT 16729
Ser No.3CS24913
Regards,
Me.
