dareksupra89
I'll take a stab at this.
The temp going from 175 to 190 should be normal. I say should because I have no idea what these new Cummins temp is.
If your driving and the temp is going from 175 to 190 then back to 175 that is nothing more than the thermostat opening at around 185(guessing) and as the cold water rushes in the temp falls back to 175 then slowly goes back up.
On my CAT the temp runs 172 to 183. I replaced the factory 195 thermostats to 180.
As for 215 at while idling is the engine fan on or off?
If its off theres your problem. Lack of air flow thru the radiator.
