Fuel Benefits of ATF in Diesel Fuel
Put a gallon of atf in the ole Detroit today. Running much smoother at idle and got about 0.3 mpg better running from Minnesota to rapid city SD. Last time I did that run I was around 6.0 mpg. Today's pump figured out at 6.4 mpg.
Tazz
Infidel
Not to be a negative nelly but where both of those on the same fuel blend?
I come home from Chicago and I normally stop at Sparta.
The last time I stopped there for fuel and then came West was in early Dec.
Was it the same fuel blend, I doubt it.
I just know I've been having a rough idle lately and it doesn't show now. Starting seems to be a tad better as well.
Tazz
Infidel
Cool And it may very well be a benefit. But when you posted that , my question popped into my head. We are changing blends right now and needs to be considered when evaluating any MPG changes.
ironpony
Professional Pot-Stirrer
A state tax authority finds red fuel in your commercial fuel tanks is gonna require a whole bunch of 'splaining. "I put ATF in there," is the usual dodge I'm told.
And I would simply step out of my truck with my caterpillar SOS test bottle pull a fuel sample smile and say have a nice day.
The test sample would show that it is ATF and not dye
That's fine.
The judge can toss it then based off the fact the spectroscopy came back declaring it atf.
THAT is called due process.
Tazz
Infidel
Dyed fuel is beat juice red. 1:150 (1 gallon in 150 gallons) is going to be a slightly pink tinge. Show them the empty gallons and they probably don't flinch. Just complain about new diesel, and the man screwing over everyone with the EPA, bitch a little.......They will probably join in ;)
Quack
Yeah. Even less.
The truck I drive would be 1:300.
And that's only if a whole gallon is dumped in.
Once a week I split a quart between the two tanks.
So it's 1:1200 on Monday afternoon and then 1:2400 on Wednesday when I put about 150 gallons in,...
ironpony
I think ya'd be better off drainin' some goop outta the KFC grease trap 'n burnin' that.
