Being as this is a four year old thread I am going to take liberty here.
We had a trailer where the valve was pissing out air. So my partner starts hammering on it as was the style with the old valves.
Broken pieces of plastic everywhere.
So I hook to the trailer and the valve is leaking and I start hammering on it. As was the style with the old valves. Broken pieces of plastic everywhere.
Had to call out a mechanic who told us don't hammer on these new valves as was the style with the old valves.
These plastic pieces of crap are expensive!
100 % is compressor !! I did the same you did and problem was the same !! So I try compressor ! There are two lines to the governor . One is to sense tank pressure . The other line is a signal line to the air dryer to tell it to purge or blow off when the tank pressure line is at 120 psi !! Good luck
